Issue with Starnet++
5 replies to this topic
#1 Stephanh
Stephanh
Posted 17 April 2021 - 09:53 AM
I am trying to run an image through Starnet++.  The program goes to 100% and closes but no starless image is generated.
While it is running, there is that weird message generated in the DOS message box.
I have run it successfully before so I know it works but not with this last image.
Anyone has an idea what the problem could be?
#2 Pete_xl
Pete_xl
  • Loc: Germany
Posted 17 April 2021 - 10:27 AM
I think I once had this message when I fed starnet++ with a PS tif file that contained layers. I saved it again from Lightroom as a normal tif and it then worked fine
#3 Stephanh
Stephanh
Posted 17 April 2021 - 11:25 AM
There are no layers in the image.  I even merged everything and then saved as a tiff file; same result.
#4 pfile
pfile
Posted 17 April 2021 - 02:41 PM
there is a warning there from libtiff about the incompatible type in that RichTIFFIPTC tag... can you save the file in such a way that no IPTC tags are generated?
rob
#5 Stephanh
Stephanh
Posted 17 April 2021 - 03:01 PM
I saw the warning but do not understand it. I saved the file the same way I have saved all previous ones that worked.
#6 Pete_xl
Pete_xl
  • Loc: Germany
Posted 18 April 2021 - 10:01 AM
I just saw the same message when starnet++ was processing a tif file that was saved from PS. I loaded it into LR and saved it as an sRGB tif. Starnet++ processed it without problems.
