Some Asteroid photometry and animation
6 replies to this topic
#1 Lukey
Lukey
  • Loc: Norfolk, England, UK, 52°N
Posted 17 April 2021 - 10:42 AM
Had a very interesting session doing some photometry on asteroids last night.
You can usually observe their rotation by a dip in the magnitude over a period of time. The more irregular ones show the greatest fluctuation. I noticed that asteroid 1727 Mette is well-placed in Serpens and has a fast rotation of about 3 hours, and I managed to capture 5 hours-worth of images. It's just a small object about 5-8 km in diameter and is a Mars-crosser asteroid, orbiting every 2.52 years.
Here is a light curve I prepared using data from the photometry program Muniwin. It's derived from 100 x 3 minute exposures, binned 2x captured with an Atik383L+, Omegon RC cam.
Once Muniwin had processed the data it came up with this strikingly obvious rotation curve, with its magnitude ranging by about 0.35 magnitudes over a period of 3 hours, matching the official rotational data with a peak at around 23:37 and another at 2:32. As usual with asteroid magnitude curves, there are two peaks and troughs per rotation. There are a few binary asteroids, like Antiope, which behave like eclipsing binaries when lined up correctly, so I hope to capture that some time. Times are British Summer Time (1 hour ahead of UT)
Here's a capture of the whole field, with the position of Mette at 22:24 and 2:57 highlighted. Based on two 5 x 3 minute exposures. The brightest star here is magnitude 7.8 and the field of view is 38.5 x 29 arc minutes.
And here's an animation of 9 cropped frames over the session, 15 minutes apart
Edited by Lukey, 18 April 2021 - 06:40 AM.
  • Magellanico, tboss70, Mike Phillips and 15 others like this
#2 moxican
moxican
  • Loc: Toronto, Canada
Posted 17 April 2021 - 11:36 AM
That is fantastic. What scope did you use?
  • Mike Phillips likes this
#3 Lukey
Lukey
Posted 17 April 2021 - 11:39 AM
Thanks! It’s an 8” f/8 Ritchey-Chretien.
#4 Aquat0ne
Aquat0ne
Posted 17 April 2021 - 04:55 PM
Great stuff. Love the animation too.
#5 jlecomte
jlecomte
  • Loc: San Jose, CA, USA
Posted 17 April 2021 - 06:54 PM
Hi, what software did you use to generate the light curve? I dabbled in AstroImageJ, but it seems to have a hard time with moving targets like asteroids. Thanks!
#6 Lukey
Lukey
Posted 18 April 2021 - 03:37 AM
The data to analyse the photometry was a program called Muniwin, but the light curve was done using Excel.  Muniwin can export the photometric data as a text file, which I imported into Excel and played around with the graphs. Muniwin creates a light curve too, so you don’t need to go to that bother, but I like the flexibility and varieties of graphs available in Excel.
Edited by Lukey, 18 April 2021 - 03:39 AM.
#7 BinaryField
BinaryField
Posted 19 April 2021 - 01:38 PM
I'm not sure if you're aware of this, but there are some special instructions to use AIJ with moving objects. I've experimented with it only a little bit myself, but it seemed to work for me.
http://astroimagej.1...ield-td240.html
  • jlecomte likes this
