Best way to plug old screw holes in an OTA?
18 replies to this topic
#1 thecelloronin
thecelloronin
  • Loc: Charleston, SC
Posted 17 April 2021 - 11:14 AM
This question applies to both steel and sonotube. What's your recommended method and material for plugging old holes?
  • teashea likes this
#2 mboothe
mboothe
Posted 17 April 2021 - 11:21 AM
Screws are the commonly accepted method of plugging unused screw holes. Barring that, plastic plugs can be purchased for the purpose. If painting is desired bondo or other hardening putty can be used. I think that’s all I’ve got.
Edited by mboothe, 17 April 2021 - 11:22 AM.
  • thecelloronin likes this
#3 greenstars3
greenstars3
  • Loc: Wind River valley
Posted 17 April 2021 - 11:27 AM
A short screw of the same thread and diameter as the original hole works great in SCT tubes that have threaded holes and in sonotubes just use black spray paint on the nuts that will go on the inside of the tube before installing
Robert
edit:mboothe you posted while I was typing - I agree
Edited by greenstars3, 17 April 2021 - 11:30 AM.
#4 havasman
havasman
  • Loc: Dallas, Texas
Posted 17 April 2021 - 11:54 AM
I like simple solutions that work. When I replaced the spider on the XT10i I covered the old holes with a little piece of gaffers tape on the inside and out. That was years ago and it's never once come to mind since.
  • izar187, cookjaiii, jmiller1001 and 1 other like this
#5 daquad
daquad
Posted 17 April 2021 - 01:44 PM
In my scopes I tape the inside of the hole with aluminum repair tape, then fill the hole with epoxy and smooth to the tube  surface with a putty knife.  After the epoxy cures, the inside tape can be removed and a dab of flat black paint applied.  If you sand and repaint the outside of the tube, the repair disappears.
Dom Q.
  • Ernesto.Nicola, Kunama and thecelloronin like this
#6 thecelloronin
thecelloronin
Posted 17 April 2021 - 01:55 PM
Thanks y'all, I got what I came for here.
#7 izar187
izar187
  • Loc: 43N
Posted 17 April 2021 - 04:41 PM
I confess to touching up the hole on the inside of the tube with black, and the outside of the tube with the color that the tube is on the outside... and ignoring them after that.
#8 MitchAlsup
MitchAlsup
Posted 17 April 2021 - 05:11 PM
Sonotube can have holes fixed with paper machete or epoxy.
Metal tubes can be epoxied, welded, brazed, fiber glassed, riveted, or have a bolt cinched up.
#9 gene 4181
gene 4181
  • Loc: n.e. ohio
Posted 17 April 2021 - 07:07 PM
  • MellonLake likes this
#10 sevenofnine
sevenofnine
  • Loc: Santa Rosa, California
Posted 18 April 2021 - 06:45 PM
If the holes are small there are plugs made for drip irrigation systems that work really well. Cheap and just press them in. waytogo.gif
Edited by sevenofnine, 18 April 2021 - 06:46 PM.
  • FoxIslandHiker likes this
#11 teashea
teashea
  • Loc: Lincoln, Nebraska, USA
Posted 18 April 2021 - 09:04 PM
You can go to Ace Hardware and check out the plastic hole plugs that they sell.
  • kfiscus, FoxIslandHiker and thecelloronin like this
#12 SteveG
SteveG
  • Loc: Seattle, WA
Posted 19 April 2021 - 05:05 PM
https://www.mcmaster...-panel-plugs-6/
#13 Jon Isaacs
Posted 19 April 2021 - 05:15 PM
:waytogo:
Even with a refractor, I'll cover a hole with a piece of tape.  A small hole or two is of little consequence and I may want use the hole again later.
Few OTAs are anything close to sealed. One only has to inspect the focuser to see large gaps..
  • airbleeder likes this
#14 teashea
teashea
Posted 19 April 2021 - 07:15 PM
Unless one is interested in visual aesthetics.
#15 Jon Isaacs
Posted 20 April 2021 - 09:50 AM
The holes the OTA are glaringly obvious...
Or maybe not..
#16 thecelloronin
thecelloronin
Posted 20 April 2021 - 12:18 PM
Where's Waldo?
#17 PJ Anway
PJ Anway
    Double-Star Observer
  • Loc: North Coast 46°N 86°W
Posted 23 April 2021 - 06:51 PM
Here is what I used to plug the screw holes in my metal OTA from removing the dob's altitude bearings (I converted my newt to a ring/dovetail mount).
Black plastic rivet with a rubber washer inside. The plastic rivets work good and can be shorten easily with cutting pliers, but they are loose. The added rubber pushed on from inside the OTA tightens the rivet.
  • SteveG and FoxIslandHiker like this
#18 SteveG
SteveG
  • Loc: Seattle, WA
Posted 24 April 2021 - 12:11 AM
Where do you get them?
#19 PJ Anway
PJ Anway
Posted 24 April 2021 - 10:38 AM
I got mine at the local hardware store, but you can get them at Graingers, MSC hardware, amazon, ebay, etc. Some places call them "panel rivets".
  • izar187 likes this
