Jupiter Northern Hemisphere this year
8 replies to this topic
#1 smiles233
smiles233
  • Loc: upstate ny
Posted 17 April 2021 - 12:06 PM
I was looking at Jupiter at opposition in upstate New York and it looks like it will be lower in the sky than last year 33 degrees Maybe. Is this correct? When I looked ahead to next year look like it will be at 48 degrees and higher
#2 Tangerman
Tangerman
  • Loc: Atlanta, Georgia
Posted 17 April 2021 - 12:27 PM
Looks to me like it'll be about 8 degrees higher this year than last year. But still pretty low. Next year it will be significantly higher, continuing to get higher for a couple years afterwards.
  • Illinois, payner and Redbetter like this
#3 Redbetter
Redbetter
  • Loc: Central Valley, CA
Posted 17 April 2021 - 12:36 PM
Jupiter was near its lowest at opposition last year.  It will be higher in the sky this year and higher again for the next several.
  • payner likes this
#4 smiles233
smiles233
  • Loc: upstate ny
Posted 17 April 2021 - 02:38 PM
Great thanks
#5 sanbai
sanbai
  • Loc: Baton Rouge, LA
Posted 17 April 2021 - 03:03 PM
Declination of Jupiter at opposition according to Skysafari:
-21° 54' in 2020-07-14
-13° 34' in 2021-08-19
-0 ° 01' in 2022-09-26 (crossing the celestial equator N ->S few hours before opposition!)
Jupiter is/was some degrees northern before the listed opposition
Edited by sanbai, 17 April 2021 - 03:04 PM.
  • Dave Mitsky likes this
#6 Dave Mitsky
Dave Mitsky
  • Loc: PA, USA, Planet Earth
Posted 18 April 2021 - 06:53 PM
The web page at https://www.astroima...date=2021-08-20 shows how Jupiter will increase and decrease in size and brightness this year.  After the 2022 opposition, Jupiter will be smaller and a bit fainter with each successive opposition until the 2030 opposition.
#7 ButterFly
ButterFly
Posted 24 April 2021 - 06:35 PM
Watching things unfold at high speed is a very helpful tool to understand both solar system motions, and how Earth's motion affects the way those motions appear against the stars.  There is a cycle, so it's impossible to tell where you are on it without also looking at the surrounding years.  If you happen to know the extremes of the cycle beforehand, then you can know whether you are there or not.
In Stellarium, turn off the ground and daylight options, turn on EQ mode, center on Jupiter, then let the time run forward very quickly.  Turning on the ecliptic guide line helps a lot.  You can also turn on its path (rather than its orbit) to watch epicycles.  Same with the other planets.  Give them a good watch at very high speed.  Saturn's rings' tilt cycle, and resonance of moons are other fun things to watch.
Unfortunately, the native GUI of Stellarium can't adjust the time step, only it's speed.  Redshift would let me select time steps of a synodic period of the selected target, for example.  That's a very, very useful tool, but needs scripting for Stellarium to do it.  If someone has or knows of such a script, please share.
  • EverlastingSky likes this
#8 Stewc14
Stewc14
  • Loc: Pueblo West colorado
Posted 28 April 2021 - 06:08 AM
I can tell you that the image sucks here in Colorado.
pushed the big refractor out and started with 8 mm, boiling away, then 10, then 14 and still won’t produce a good image . So I’ll go out and try 18.2 in an hour. Waited all winter,,,,,,,,,,,,,,,,I’ve been disappointed before. Looks to be 17 to 20 degrees. Maybe a few more degrees will improve the image.
#9 ButterFly
ButterFly
Posted 28 April 2021 - 01:27 PM
Try just before sunrise.  It's about 30 degrees up for 35N at sunrise.  Jupiter can be pushed rather far into twilight, and gets to about 35 degrees an hour after.
