What is the best scope for AP < $1k?
5 replies to this topic
#1 chanrobi
chanrobi
Posted 18 April 2021 - 11:13 AM
Couple of requirements:
1) Has to be able to attach to my dslr (eos m)
2) Focal length 400-600mm
3) Cannot be slow (f/5 or faster) <- Is this possible? necessary?
4) Can have a ... extender put on? <- Is this possible?
I've been shooting for the last year with a 135mm f/2 lens and this is just way too wide for most of the stuff I want to do. I've looked at scopes like
- redcat, radian raptor (not enough FL)
- ES AR102 F/6.5 (inside budget but seems slow?)
I have very limited time most nights to go out and shoot, so i'd like to get the most data possible for that time (= need fast scope?). Or would aperture trump that?
Suggestions?
#2 Normmalin
Normmalin
  • Loc: SE Michigan
Posted 18 April 2021 - 11:22 AM
I'll just answer from a spec perspective.  Can't talk to quality comparisons between scopes you mention.
Williams Optics Zenithstar 73 is a 430mm (f/5.9) but with field flattener/0.8x focal reducer gets you to 344mm (f/4.7).  The total cost of the scope plus flattener/reducer is $1k.
Edited by Normmalin, 18 April 2021 - 11:23 AM.
#3 dswtan
dswtan
  • Loc: Morgan Hill, CA
Posted 18 April 2021 - 11:25 AM
What mount do you have? If you're talking about DSO astrophotography, you'll be best to budget your 1k on the mount and get a cheap refractor to put on it to upgrade from a 135mm camera lens.
Best forum then for this question would be https://www.cloudyni...ep-sky-imaging/ .
#4 alan.dang
alan.dang
Posted 18 April 2021 - 11:32 AM
Canon EF 400/5.6L
Air spaced 72mm triplet with flattener.
#5 Lead_Weight
Lead_Weight
  • Loc: Houston
Posted 18 April 2021 - 11:35 AM
Askar FRA400 or FRA600. Quadruplet with full frame flat field. Both have reducers to give you even wider view and faster speed as an option.
#6 chanrobi
chanrobi
Posted 18 April 2021 - 11:56 AM
I'm not concerned about the mount at the moment, need suggestions just for scope
