Does Optolong L-extreme filter fit inside the Baader Protective T-Ring ?
3 replies to this topic
#1 Andre Moutinho
Andre Moutinho
  • Loc: Sao Paulo, Brazil
Posted 18 April 2021 - 08:51 PM
Hello all,
Does anyone know if the Optolong L-extreme 2" filter fits inside the Baader Protective T-Ring ?
The manual says that a low profile Baader filter can fit inside it. Does not mention if other filters are compatible.
Best
Andre
#2 the Elf
the Elf
  • Loc: Germany
Posted 19 April 2021 - 09:01 AM
According to Baader's web site the low profile filters are 6mm thick. Took a quick look and I'd say there is almost another 1mm gap. Optolong calls it "ultra thin filter cell". From what I see in the image it is not higher than the Baader. So, very likely yes, but I have not tried.
#3 kel123
kel123
Posted 19 April 2021 - 09:16 AM
Hello all,
Best
Andre
Once the cell is less than 6mm in thickness , it can fit. I have used two different 2" filters from different manufacturers, including optolong L-Pro and they fit. The optolong filter should fit as it seems thinner that the Baader filter. But it never hurts to confirm the thickness of the optolong filter cell.
#4 Andre Moutinho
Andre Moutinho
Posted 19 April 2021 - 09:26 AM
Thanks for the reply!
