EQMod Connect Error Timeout (worked perfectly last night)
7 replies to this topic
#1 oneredpanther
oneredpanther
Posted 20 April 2021 - 11:07 AM
I've seem to have many random issues related to ASCOM!
Last night everything ran perfectly, yet today (nothing moved or was even unplugged) I switch it on; connect the mount in PHD2 just fine, yet EQMOD insists Connect Error: Timeout.
What gives? PHD2 is literally connected, but EQMods times out. The com port is the same, nothing has changed.
Everything related to ASCOM seems less reliable than a Ugandan politician.
Ran the diagnostics - says congratulations; all tests passed! :|
Edited by oneredpanther, 20 April 2021 - 11:13 AM.
  • PirateMike likes this
#2 oneredpanther
oneredpanther
Posted 20 April 2021 - 11:12 AM
I solved the issue!
If anyone's interested in the solution: today is a day of particularly strong and fine solar radiation, with zero cloud cover. The high luminosity of my observing location obscured the light-emitting diode function of the ASCOM-driven mount hardware.
Once I identified the root cause, and actually switched the power on at the wall, everything operated nominally.
Einstein right here.
Edited by oneredpanther, 20 April 2021 - 11:14 AM.
  • jdupton, PirateMike, BrendanC and 1 other like this
#3 PirateMike
PirateMike
  • Loc: A Green Dot On A Blue Sea
Posted 20 April 2021 - 11:14 AM
Try cleaning all the cable connections.
Are you talking about Ascom or EQMod? They are not the same thing. EQMod is what runs your mount.
Miguel   8-)
#4 PirateMike
PirateMike
Posted 20 April 2021 - 11:16 AM
I solved the issue!
Miguel   8-)
#5 PirateMike
PirateMike
Posted 20 April 2021 - 11:33 AM
I always forgot to turn the mount on before trying to connect, so I had to walk back out to it just to turn it on. I just couldn't get out of the habit of forgetting for some reason. crazy.gif
Miguel   8-)
#6 ChiTownXring
ChiTownXring
  • Loc: Sugar Grove, IL
Posted 20 April 2021 - 11:47 AM
After the 2nd or 3rd time of not turning on my mount I went ahead and created a punch list and laminated it. I use it every time without fail so I am up and running quickly without having to think about "did I miss something" "on man now what's wrong" just to find out that I skipped a step.
#7 unimatrix0
unimatrix0
Posted 20 April 2021 - 12:34 PM
I do this nearly all the time. My issue is my 12V power adapter/converter cigar lighter plug is just not the most secure connection ever so I have to jiggle it around until I see the red light come up on the mount.
By the way, it's not ASCOM's fault showing a connection. ASCOM only reports the cable used has a thing-of-a-jiggie  inside at the connector, that creates a port in your PC (COM2/3/4 etc) and it's active, even if the mount is off.
It works in a similar way how old serial cable-connected devices used to work, like printers and such. For those you actually had to restart the PC after connection.
Ancient technology, should have been renewed a long time ago, if you ask me.
Edited by unimatrix0, 20 April 2021 - 12:39 PM.
#8 oneredpanther
oneredpanther
Posted 21 April 2021 - 06:31 AM
  • Don't worry, USB will make everything standard.
  • Don't worry, USB 2.0 will make everything standard.
  • Don't worry, USB Mini will make everything standard.
  • Don't worry, USB Micro will make everything standard.
  • Don't worry, USB Micro-B will make everything standard.
  • Don't worry, USB 3.0 will make everything standard.
  • Don't worry, USB-C will make everything standard.
  • sbharrat likes this
