Is a CG4 appropriate for a skywatcher 102 Mak?
10 replies to this topic
#1 Albanyco
Albanyco
  • Loc: Albany, NY
Posted 20 April 2021 - 11:10 AM
Is this a good mount for this telescope or is it too much gun? Looking for a reasonably priced mount for grab and go. If not this one does anyone have any suggestions? Thanks.
Garrett
  • PirateMike likes this
#2 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 20 April 2021 - 11:26 AM
I have a 102mm Mak that is fine for visual on my Super Polaris mount. So I would expect that the CG4 can handle that sized Mak for visual use.
#3 PirateMike
PirateMike
  • Loc: A Green Dot On A Blue Sea
Posted 20 April 2021 - 11:42 AM
I have a CG4 and it seems that the tripod is quite heavy, maybe not to good for a light "grab and go" setup but may be acceptable for you. YMMV.
Miguel   8-)
  • BlueMoon likes this
#4 hcf
hcf
Posted 20 April 2021 - 11:50 AM
If you want a lighter EQ mount you can try the ES EXOS Nano EQ
https://www.cloudyni...nano-eq-thread/
There is a review of a C90 with the mount, in that thread.
The CG-4 is more future compatible, in case you upgrade to a heavier scope later.
#5 BlueMoon
BlueMoon
  • Loc: South Central Idaho, USA
Posted 20 April 2021 - 11:51 AM
A SW Skymax 102mm Mak weighs 4.6# and is 12.5" long. Add eye piece, diagonal, red dot, and round up to say, 5#. Well within the range of a Twilight or Porta II Alt/Az if you want to stay closer to "grab n go". Not that a CG-4 is heavy, but you will still want at least a casual Polar alignment if your going to use the DEC and RA axes for movement. Alt/Az is a "setup and point" solution. As a light, short tube scope, any oscillation using any of these 3 mounts will be minimal and quickly damp out.
Clear skies.
Edited by BlueMoon, 20 April 2021 - 12:46 PM.
#6 Albanyco
Albanyco
  • Loc: Albany, NY
Posted 20 April 2021 - 12:26 PM
Thank you guys for your advice!
#7 Mike G.
Mike G.
  • Loc: Oberlin, Ohio
Posted 20 April 2021 - 03:32 PM
CG4 is almost too much mount for a 102 mak.  I have two CG4's, one with the 1.75" tubular steel legs and one with old Vixen adjustable wood legs.  either will take my C8 without breathing hard and damp in 2 seconds or less.  I also have a C6 and Synta 100mm mak but usually use either of those on my TW1.  as stated, the CG4 can be used as GnG, but a TW1 or Porta Mount (or similar) makes more sense for 100mm mak.  that said, you get a lot of extra capacity for down the road upgrades with a CG4 and with rough polar alignment and a motor kit, hands free tracking.  the CG4 on a decent tripod is a robust, reliable mount that is built to last for many years.
#8 Albanyco
Albanyco
  • Loc: Albany, NY
Posted 20 April 2021 - 05:20 PM
Thank you for your replies. I ended up skipping the CG4 and went with an explore scientific EXOS Nano. I already have a 10 inch dobsonian on wheels so I figured this manual mount would be fine for my proposed.
#9 BlueMoon
BlueMoon
Posted 20 April 2021 - 05:26 PM
Nice piece of kit and about as "grab n go" as one could want in a GEM. That should compliment your Mak pretty well I'd think. I don't know if you saw it but here's a CN thread on the topic on the Nano: https://www.cloudyni...nano-eq-thread/
Clear skies.
Edited by BlueMoon, 20 April 2021 - 05:27 PM.
#10 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 20 April 2021 - 05:55 PM
Agreed. Nothing wrong with trying to keep it simple if that fits your needs.
#11 hcf
hcf
Posted 20 April 2021 - 06:53 PM
The Counterweight on the EXOS Nano might be insufficient (or barely sufficient) for  the Mak. If you can, add a CW from ES to your order.
There are some links to appropriate CWs from ES on the EXOS Nano Thread.
