Just got my ZWO ASI 2600MC
14 replies to this topic
#1 KarthikNagaraj
KarthikNagaraj
Posted 20 April 2021 - 11:11 AM
I'm so excited. I;'m at a bortle 5 zone and typically shoot from my backyard. For Galaxies should I use a light pollution filter like the L-Pro or Astronomik CLS/CCD with this camera? Or can I just shoot bare and then edit in PixInsight? Or should I use a Luminance UV/IR cut filter? Any suggestions might be helpful. Thanks
  • PirateMike and acommonsoul like this
#2 PirateMike
PirateMike
  • Loc: A Green Dot On A Blue Sea
Posted 20 April 2021 - 11:29 AM
I would try the camera without a filter to see if the results are acceptable before even considering to buy a filter. Such a "determination path" could save you some money.
Miguel   8-)
  • Jim Waters and TrustyChords like this
#3 Stelios
Stelios
  • Loc: West Hills, CA
Posted 20 April 2021 - 11:32 AM
You only need an UV/IR-cut filter, which for this camera is already built in. No L-Pro or CLS-CCD, you'll lose data for galaxies.
  • jonnybravo0311 and chili555 like this
#4 KarthikNagaraj
KarthikNagaraj
Posted 20 April 2021 - 11:34 AM
#5 adosaj
adosaj
Posted 20 April 2021 - 11:36 AM
Living in the Bay Area, my “dark site” is B4/5 :) I don’t use any filters with my mono camera except LRGB or narrowband and the images a fine. If I was going to use a OSC camera, I would just use an UV/IR cut. You do not need a LP filter.
Anil
#6 maxsid
maxsid
  • Loc: Sunnyvale, CA
Posted 20 April 2021 - 11:48 AM
The camera has it's own UV/IR cut window - no need to use another one.
I stopped using L-Pro and such - they do more bad than good IMHO.
I do use an L-eNhance for Ha rich nebulas - it basically produces Ha+OIII narrow band images and effectively filters out light pollution and even moon light.
Edited by maxsid, 20 April 2021 - 11:49 AM.
  • bobzeq25, TrustyChords and KarthikNagaraj like this
#7 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 20 April 2021 - 11:51 AM
I would use just the UV/IR-cut filter. No L-Pro or CLS-CCD, you'll lose data for galaxies.
No need.  The front window is an UV/IR filter.
  • jonnybravo0311 and KarthikNagaraj like this
#8 KarthikNagaraj
KarthikNagaraj
Posted 20 April 2021 - 11:54 AM
Nice. did not know that the front window of the 2600MC is in fact a UV IR cut. Is that the same for the 2600MM too? Why then do people recommend an L filter in the LRGB subs - can't we just shoot? wouldn't the L be equivalent to the front window's UV/IR cut?
#9 KarthikNagaraj
KarthikNagaraj
Posted 20 April 2021 - 11:57 AM
Ok just saw this in more details:
https://astronomy-im...600mc-pro-color
"Protect window: D60-2 IR Cut"
And its twin 2600MM has this:
Protect window: D60-2 AR
What is AR?
https://astronomy-im...2600mm-pro-mono
Edited by KarthikNagaraj, 20 April 2021 - 11:58 AM.
#10 drake
drake
  • Loc: Naples, Italy
Posted 20 April 2021 - 11:58 AM
how is the quality of your sky?
I'm living in bortle 6-7 and can not do without it
#11 maxsid
maxsid
Posted 20 April 2021 - 12:05 PM
Bortle 8.
#12 KarthikNagaraj
KarthikNagaraj
Btw, this link explains it:
https://astronomy-im...dow-asi-cameras
AR window is mostly a dust and humidity protect window that allows from light from 350nm to 1050nm+ so 2600MM Pro is just a AR cut window hence the Luminance filter.
IR window is dust + humidity + cut off UV and IR and allows only from 400nm to 700nm. The 2600MC has this window and hence no need of any filter. Just shoot barebones.
Wow, mind blown. Thanks people this helped me save 100s of $ of simply buying a filter because I felt it was needed. bow.gif
Edited by KarthikNagaraj, 20 April 2021 - 12:06 PM.
#13 Peter in Reno
Peter in Reno
  • Loc: Reno, NV
What is AR?
AR = Anti-Reflection
Peter
  • acommonsoul and KarthikNagaraj like this
#14 drake
drake
Posted 20 April 2021 - 12:54 PM
Bortle 8.
I have to review again my processing method without filters.
#15 Stelios
Stelios
Posted 20 April 2021 - 06:08 PM
Thanks, I modified my original post.
