Markov's Chain over Mt. Lassen
Imaging DSO
13 replies to this topic
#1 dheera
dheera
  • Loc: San Francisco
Posted 20 April 2021 - 12:04 PM
Hi everyone! After a little hiatus with some bad weather spells I'm back with another deep sky landscape! This one is slightly less "in your face" but took a lot more effort to plan and line up.
Here's Markarian's Chain rising over Mt. Lassen in California, as seen with a 500mm lens from far away!
More "deepscapes" on my Instagram: https://instagram.com/dheeranet/
51127838083_f1d4a47b30_h.jpgMarkov Chain over Lassen by Dheera Venkatraman, on Flickr
Edited by dheera, 20 April 2021 - 12:05 PM.
  • dswtan, Wigleydh, ub0423 and 23 others like this
#2 descott12
descott12
  • Loc: Charlotte, NC
Posted 20 April 2021 - 12:16 PM
Fantastic perspective! I can't view your linked page. Could you please describe how you did this?  Did you combine different exposures I am guessing??
#3 BlueMoon
BlueMoon
  • Loc: South Central Idaho, USA
Posted 20 April 2021 - 12:19 PM
A real beauty. Bravo!
Edited by BlueMoon, 20 April 2021 - 05:17 PM.
#4 Sky King
Sky King
  • Loc: Arizona
Posted 20 April 2021 - 12:21 PM
Great concept and execution! Breathtaking!
#5 dheera
dheera
Posted 20 April 2021 - 12:23 PM
Yes, the perspective is real but noise-reduced by an untracked ground stack and a tracked sky stack that was started once it rose to the appropriate height.
Edited by dheera, 20 April 2021 - 12:23 PM.
  • AlwaysHungry likes this
#6 jimr2
jimr2
  • Loc: Sparks, NV
Posted 20 April 2021 - 12:40 PM
Very beautiful shots--or shots--Dheera! Was wondering...could you tell me/us where exactly in Lassen NP you took this photo from? I'm going to be in the Park later this summer and would love to be able to attempt some shots w/ my DSLR on a tracking mount, etc., from your set-up site so I don't have to spend a lot of time hunting around for a good location.
Thanks!, Again, great photo!
-jim r-
#7 lattitrail
lattitrail
  • Loc: McCook, Nebraska
Posted 20 April 2021 - 12:43 PM
This high level of creativity is why I love and find the hobby so inspiring. Incredible perspective, thank you for sharing!
#8 Astrola72
Astrola72
  • Loc: Maryland, USA
Posted 20 April 2021 - 12:47 PM
Dheera - All your work is excellent, but the "deep sky landscapes" are brilliant! Please, keep them coming!
Joe
#9 lynnelkriver
lynnelkriver
  • Loc: Elk River, Mn.
Posted 20 April 2021 - 12:52 PM
Nicely done!  All the best, Scott
#10 Dan_I
Dan_I
  • Loc: France
Posted 20 April 2021 - 02:33 PM
Very good concept, and well done too ! I guess you have to be very precise with the choice of imaging spot and acquisition time ?
#11 Mert
Mert
  • Loc: Spain, Pamplona
Posted 20 April 2021 - 02:44 PM
I am speachless by the beauty of this image, another breathtaking creation, excepcionally well done!
#12 dheera
dheera
Posted 20 April 2021 - 02:50 PM
Yes, there was an exact spot where this is possible. Even though I was over 40 kilometers away from the mountain, if I had moved even a few hundred meters of where I was, this alignment wouldn't have happened. I spend a lot of time looking for these alignments smile.gif it's not that different from aligning such mountains with the moon though. (Actually the moon is actually harder to plan for with because it moves to different RA every day, and the galaxies stay put at the same RA for millenia.)
Edited by dheera, 20 April 2021 - 02:53 PM.
#13 dheera
dheera
Posted 20 April 2021 - 03:01 PM
-jim r-
I usually don't post exact locations online to avoid eventual overcrowding at places that aren't designed for crowds, but here are some tips:
- I didn't take this from within the national park, but a few dozen kilometers away from it. That's the only way I could zoom in enough on the mountain to get the Markarian's Chain to the same field of view. If you try to shoot Lassen from within the national park, you'll have to inevitably use a wider lens to frame the mountain, and you can't frame DSOs like these in the same frame.
- If you want to shoot deepscapes, the trick is to look for what Azimuth the DSO rises from and then look in the opposite direction straight line for convenient viewpoints e.g. open fields, peaks, or vista points you can get to, that aren't on private property, or that you can get permission to be on. There is an app called PlanIt Pro that helps a lot with this planning.
- If you just want to shoot just DSOs alone and not deepscapes like this, inside the national park IS a good place to be. The sky is really really dark there, darker than where I shot this from. Pretty much anywhere in the park with open views is a good place.
- If you want to shoot Markarian's Chain, later in summer is not a good time. Now is a good time -- it's already at 30+ degrees up in the sky after sunset. But there are lots of other things to shoot later in summer.
- In the off-chance that you're not local to CA, wildfires are a common occurrence later in summer so plan some backup options. I wouldn't bet on a particular location being good for imaging late in summer.
Edited by dheera, 20 April 2021 - 03:12 PM.
  • Sky King likes this
#14 xonefs
xonefs
Posted 20 April 2021 - 03:49 PM
Whoa that's a great idea and execution
Also tagged with one or more of these keywords: Imaging, DSO
