What's your Berlebach?
5 replies to this topic
#1 25585
25585
  • Loc: In a valley, in the UK. Dark end of the street.
Posted 20 April 2021 - 12:35 PM
Thinking about either a Uni 28 or Planet... so inspiration from Berlebach tripod & other gear owners helpful.
What have you got or are aspiring to?
Can Bb tripod legs be fitted to Tele Vue Gibraltar tripod tops?
#2 mtminnesota
mtminnesota
  • Loc: St. Paul
Posted 20 April 2021 - 01:52 PM
Having owned both, I recommend the Planet.  It's only about 6 1/2 lbs heavier but it's far more solid.  Although if you're mounting a very light scope/mount on it, you might not benefit as much from that extra stability.
  • 25585 likes this
#3 Keith NC
Keith NC
  • Loc: Guilford County North Carolina
Posted 20 April 2021 - 03:47 PM
Planet is a BIG tripod !  I have a 130mm refractor with a DM6 and that combination puts no stress or strain on the Planet.  I do not know where the Planet might limit out but do know it’s a lot more than 130mm for sure.  I think the latest version of the TeleVue Gibraltar mount utilizes the Uni tripod.  Certainly the Planet gives you more room to mount larger scopes
good luck with your choice
  • 25585 likes this
#4 gnowellsct
gnowellsct
Posted 20 April 2021 - 04:28 PM
I use the Planet for everything from 81mm to c8.
Beyond that I switch to the ATS portable pier.
I do not recommend going "light weight" on this particular item.  Put a g8 on your tripod instead of a g11 if you must (or other equivalents) but the tripod is not a good place to save money or weight.
Incidentally the Losmandy machined aluminum tripods are excellent but I found them hard to use in winter.
Greg N
  • 25585 and mtminnesota like this
#5 bthrel
bthrel
  • Loc: Linden TN
Posted 21 April 2021 - 06:51 AM
Uni 18 with M2C mounting a 120MM F7.5 refractor .. very solid  setup for me.
Edited by bthrel, 21 April 2021 - 06:56 AM.
  • payner, ngc6352 and 25585 like this
#6 Jeff Bennett
Jeff Bennett
  • Loc: Clayton, California
Posted 21 April 2021 - 10:54 AM
I have both the Uni-28, currently with a DM-4 mount, and a Planet with DM-6.  As others have said, the Planet gives you a lot of upside in terms of the type of mount and scope you use it with, but you will notice the difference in weight.
I had the Uni-28 first and actually put my DM-6 on it, and it worked well with the 130mm F7 refractor that I had at that time.  I even used it with my TEC 140, but that scope is what pushed me to get a planet for additional stability.  I am certain that the Planet/DM-6 combo would handle a 160mm F7-8 refractor without too much trouble.  I will say that I leave my mounts attached to their tripods, and the Planet/DM-6 is somewhat of a beast if you have to carry it very far.  The Uni/DM4 feels a lot easier to carry around, though much of that is the lighter mount itself.
In the end, it really depends on the mount/scope combo you are looking at and how much future versatility you want for a bigger scope.
  • 25585 likes this
