May 2nd H-Alpha
17 replies to this topic
#1 wargrafix
wargrafix
  • Loc: Trinidad
Posted 04 May 2021 - 10:35 AM
Trying to diagnose the double limb issue, I focused on what may be incurring the error. Visually when in focus, the double limb can be seen.
Adjusting the tilt doesn't seem to have any meaningful change. Either of the etalons, did very little to change the limb issue. I will try without the 2X barlow to see if it is incurring errors.
Here are different limb locations. The "left side is always better in terms of the limb issue.
Coronado Solarmax 2 60mm DS
2x barlow
ASI224MC
right side with limb issue
Edited by wargrafix, 04 May 2021 - 10:47 AM.
  • peterm, MAURITS, hopskipson and 4 others like this
#2 HPaleske
HPaleske
Posted 04 May 2021 - 12:10 PM
good job!  The results appear sufficiently homogeneous.
cs Harald
www.unigraphprom.de
#3 peterm
peterm
  • Loc: Gold Coast, Queensland, Australia
Posted 04 May 2021 - 07:09 PM
Well done indeed!
#4 hopskipson
hopskipson
  • Loc: Queens, New Yawk, Light pollution Headquarters!
Posted 04 May 2021 - 07:37 PM
Nice job! I really like the first one with the long chain of filaments ending in a filaprom.
#5 wargrafix
wargrafix
  • Loc: Trinidad
Posted 05 May 2021 - 06:37 AM
Thank you everyone! I am unsure what is inducing the partial double limb
#6 HPaleske
HPaleske
Posted 05 May 2021 - 10:40 AM
I think
a) that the flanks of the halp line are not steep enough and therefore parisitic photosphere light penetrates. Only the specification of the half value width is not enough. or
b) the half value width is not yet tight enough or
c) Etalone finesse is not good enough
d) The beam path is not slim enough
cs Harald
www.unigraphprom.de
#7 wargrafix
wargrafix
  • Loc: Trinidad
Posted 05 May 2021 - 12:52 PM
How do I correct for that?
#8 HPaleske
HPaleske
Posted 05 May 2021 - 01:08 PM
The easiest way is to improve the focal ratio to make the optical path slimmer (d). However, the telecentricity must be maintained. This is not possible with a simple barlow. You need a stronger telecentric for this. However, this leads to a long focal length. The focal length must then be reduced again.
The other three possibilities, a) to c), can only be improved by higher quality etalons.
update:
There is one more possibility.  Use three etalons (tristack).
Unfortunately, the brightness then decreases rapidly and the etalons must be aligned exactly.
cs Harald
www.unigraphprom.de
Edited by HPaleske, 05 May 2021 - 01:12 PM.
#9 astro rocketeer
astro rocketeer
  • Loc: Valencia, CA (Los Angeles)
Posted 05 May 2021 - 02:20 PM
looks very nice!
#10 wargrafix
wargrafix
  • Loc: Trinidad
Posted 05 May 2021 - 04:25 PM
Are you referring to a telecentric barlow?
#11 wargrafix
wargrafix
  • Loc: Trinidad
Posted 05 May 2021 - 04:27 PM
Also.....Grrrrrrrr. this rainy weather is projected to go on for another week!
#12 hopskipson
hopskipson
Posted 05 May 2021 - 04:52 PM
A telecentric is an amplifier that also creates a parallel light path before it enters an etalon such as with a Quark.  Baader makes them to use with Solar Spectrum and DayStar SE, PE, and Ion etalons.
#13 HPaleske
HPaleske
"...Are you referring to a telecentric barlow?"
No, it should be a real telecentric system (example Baader a.o., Unfortunately only quadruple magnification .)
cs Harald
www.unigraphprom.de
#14 hopskipson
hopskipson
Posted 05 May 2021 - 05:07 PM
cs Harald
www.unigraphprom.de
Hi Harald
I'm not sure a telecentric is going to help the OP.  The scope in question is a Solarmax II which use internal and external etalons.  Unless I'm missing something.  I have the Solarmax II also and I can attest that the etalon finesse is not that great.
#15 HPaleske
HPaleske
Posted 05 May 2021 - 06:05 PM
James,
the slimmer the beam path, the easier it is for the etalons to work properly, which means a small aperture ratio.  Of course, there is nothing you can do if the etalons are of poor quality.
I use select Lunt 35mm etalons. There are big differences.
cs Harald
www.unigraphprom.de
  • hopskipson likes this
#16 wargrafix
wargrafix
  • Loc: Trinidad
Posted 05 May 2021 - 07:05 PM
I use vivitar teleconverters for my planetary work, and they make regular barlows look like a joke.
The 2x requires a bit more infocus distance.
When I get clear skies I need to try my 3x teleconverter
#17 wargrafix
wargrafix
  • Loc: Trinidad
Posted 06 May 2021 - 02:11 PM
#18 rigel123
rigel123
  • Loc: SW Ohio
Posted 06 May 2021 - 08:22 PM
Those last two images look fantastic!
Edited by rigel123, 06 May 2021 - 08:23 PM.
