Recementing a 3" Achromatic objective
8 replies to this topic
#1 Valmigo
Valmigo
  • Loc: St Augustine, FL
Posted 04 May 2021 - 04:13 PM
Does anyone know of an optical company that can do this job?
#2 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 04 May 2021 - 04:40 PM
I know there are companies that do it because the previous owner of my TMB 80 SS triplet had it fixed from the same problem. He never told me the company's name but said it was a larger well known optical company.
#3 siriusandthepup
siriusandthepup
  • Loc: Central Texas, USA
Posted 04 May 2021 - 05:06 PM
Cemented objective issues
From CN. Not an impossible job for a patient person. Does not cost much to do it either.
#4 RichA
RichA
  • Loc: Toronto, Canada
Posted 04 May 2021 - 05:21 PM
For the heck of it, could always try air-spacing in the interim.
#5 BGRE
BGRE
  • Loc: New Zealand
Posted 04 May 2021 - 05:52 PM
If using UV cured adhesive such as NOA61 its important that UV illumination non uniformity across the adhesive layer be less than 10% or measurable aberrations due to index gradients etc within the cured adhesive layer will occur. Similar non uniformities when using optical epoxies can also occur if the epoxy is left on the first element for more than a few seconds before the second element makes contact.:
https://www.research...ic_applications
#6 Steve Dodds
Steve Dodds
  • Loc: Utah
Posted 04 May 2021 - 06:00 PM
You could probably just put it out in the Sun.
#7 ccaissie
ccaissie
  • Loc: Whitefield, Maine
Posted 05 May 2021 - 07:25 AM
De-cementing it is probably the crux.  You could air space it, or oil it.  Usually 3" is a practical limit for cementing.  We have a 4" triplet made by Stan Brower...found it in a junk box.  It star tests horribly...big astigmatism, the cementing has bubbles/voids.  One of our members got excited at the find and started a formal build, cell, focuser.   I slapped together a tube to test it out, and it has now never been in use.
It would be interesting to de-cement it and redo it.  It hasn't come up near the top of anyone's  "to do" list.  Older Balsam cemented lenses come apart with heat and solvent...I have no idea how to de-cement something with the newer polymer cements.
#8 DAVIDG
DAVIDG
  • Loc: Hockessin, De
Posted 05 May 2021 - 08:53 AM
 I have done it many times, here is a  link to my thread on  how I typically  do it  https://www.cloudyni...ecement-a-lens/
                         - Dave
Edited by DAVIDG, 05 May 2021 - 09:18 AM.
#9 BGRE
BGRE
  • Loc: New Zealand
Posted 05 May 2021 - 09:03 AM
A report by Leica for ESA on optical cements for space applications:
http://emits.sso.esa...FinalReport.pdf
Includes method used for precision centering that doesn't rely on accurate lens edging.
Also indicates why collimated UV is desirable for curing  etc.
