HELP: ETX125 # 492 Manual Controller
Beginner Equipment Maksutov Meade Observing Catadioptric Accessories
2 replies to this topic
#1 LU1AR
LU1AR
Posted 05 May 2021 - 06:10 PM
I own an ETX 125 PE, which uses an Autostar controller, full of buttons. But I usually only use it in manual mode -in an equatorial wedge- with the # 492 manual controller, which is configured -by means of a few small screws- to rotate in the correct direction for my hemisphere.
The fact is that I made many improvements, which include Lithium Batteries and other things; that I timely published in these forums.
Now I connect the controller and the telescope does not rotate. Responds to speed control and altazimuth controls; but it has no synchronous movement.
I remembered that when starting it, you had to select something by pressing "Menu" and see some flashing dots, one of which enabled that movement. I managed to get him to do it, by trial and error.
Interestingly, the manual does not mention it.
I would like someone to remind me how that was done, so I write it down.
Thanks.
Edgardo
imagen.png.cd8a7b221f080c4e8a32962c4e8ae
#2 OzAndrewJ
OzAndrewJ
Posted 05 May 2021 - 06:37 PM
Gday Edgardo
Ref https://www.cloudyni...492-controller/
It has a section from a manual at the bottom that describes the process
  • LU1AR likes this
#3 LU1AR
LU1AR
Posted 06 May 2021 - 10:20 AM
Gday Edgardo
Thanks Andrew: Your answer solved the problem for me. I see that also; you live in the correct hemisphere.
Regards.
Edgardo - Buenos Aires - Argentina.
Also tagged with one or more of these keywords: Beginner, Equipment, Maksutov, Meade, Observing, Catadioptric, Accessories
