Easy way to keep Meteors in Pixinsight?
8 replies to this topic
#1 gerryberry
gerryberry
Posted 06 May 2021 - 10:53 AM
Me again :)
So took about 170 images of the meteor shower last night, thanks for people who helped me,
About 25 of the images have good meteor streaks in them so I would like to try and include them in my final image
Everything online is Photoshop which I dont have and new to Pixinsight so one or two of Adams one confused me,
Is there any "easy" way to do it in Pixinsight or am I better for these types of processing sticking with Photoshop?
My 300m lens arrives next week and Im good at processing galaxies with PI so I think my daily questions will cease for a while anyways!
I do appreciate everyones help though,
Ger
#2 jonnybravo0311
jonnybravo0311
  • Loc: NJ, US
Posted 06 May 2021 - 11:02 AM
Are all of your images of the same area of the sky? Example, you put your camera on a mount/tracker and imaged the same area of the sky the whole night. If yes, then I think you could keep your meteor streaks by not using any pixel rejection algorithms when integrating. Usually when you integrate images, you want satellite trails / random streaks to _not_ be included, so you use certain rejection algorithms like Winsorized Clipping or GESD.
So, do your normal calibration process (assuming you took darks/flats/biases). If you didn't, then just register and integrate the lights.
I don't know if this will work - I've never actually shot meteors and tried to keep the trails, but it's what I would try :)
  • gerryberry likes this
#3 gerryberry
gerryberry
Posted 06 May 2021 - 11:09 AM
Great will try that yes same part of the sky using tracking mount, I’ll let you know if it works thanks!
  • jonnybravo0311 likes this
#4 kathyastro
kathyastro
  • Loc: Nova Scotia
Posted 06 May 2021 - 11:22 AM
I did that when I wanted to capture an asteroid trail.  I just selected "No rejection", and it kept it.
#5 gerryberry
gerryberry
Posted 06 May 2021 - 11:30 AM
I don't know if this will work - I've never actually shot meteors and tried to keep the trails, but it's what I would try smile.gif
just to be sure
im going to run weightedbatchpreprocessing
input flats, lights, biases and darks
all settings are my usual except under lights i choose image integration - rejection method none
but in the calibration frames rejection method default?
Edited by gerryberry, 06 May 2021 - 11:31 AM.
#6 gerryberry
gerryberry
Posted 06 May 2021 - 03:50 PM
nope not sure on the above Jonny if you could add some guidance on how its done, I ran Image Integration process and added all my raw files with meteors in them and chose no rejection and doesnt seem to have worked
#7 06AwzIyI
06AwzIyI
Posted 06 May 2021 - 04:00 PM
Try it without Subframe Weighting. I'm betting those meteor streaks are kicking up the eccentricity pretty high, giving them a low weight.
#8 jonnybravo0311
jonnybravo0311
  • Loc: NJ, US
Posted 06 May 2021 - 07:22 PM
Try running WBPP only for calibration (don't have it do the registration / integration). You can do those two steps yourself. Doing it that way, you'll have full control over how to integrate.
  • jdupton likes this
#9 jdupton
jdupton
  • Loc: Central Texas, USA
Posted 06 May 2021 - 09:44 PM
Ger,
   There is a very simple way to do it but final processing will be a little different.
   As @jonnybravo0311 has suggested, run WBPP for calibration but choose not to do the integration. Run that on the aligned subs yourself. Try using the following settings in Image_Integration:
  • In the Image Integration section, Rather than choosing "Average" Combination, choose "Maximum" instead. This will pick the brightest pixel in each stack for a given pixel location. The result is the full brightness of the meteor will replace the background.
  • Choose "Adaptive Normalization" as the Normalization method to help even out some of the background gradients that result.
  • In the Pixel Rejection (1) section, either try "No Rejection" or "Min/Max" as the Rejection Algorithm.
  • If you Choose Min/Max, then choose "Adaptive Normalization" and Uncheck the option "Clip High Pixels".
  • In the Pixel Rejection (2) section, set the "Min/Max Low" value to about 10% of the number of frames you will be integrating assuming you choose Min/Max Pixel Rejection. (About 17 for your case?)
   I have used settings similar to these these when I want to emphasize asteroid trails in images. These settings can result in more gradients to remove than the normal settings so be prepared to spend a little more time in DBE for cleanup as required.
John
Edited by jdupton, 06 May 2021 - 09:46 PM.
  • pfile, jonnybravo0311 and gerryberry like this
