9.25" EDGE on GM8
2 replies to this topic
#1 Steve C.
Steve C.
  • Loc: Sugar Land, TX
Posted 07 May 2021 - 05:47 PM
I sold my CPC800 Edge a few days, and I'm wondering where the invest the proceeds.
The CPC was a good scope, but at 43 lbs for the fork and OTA, it just became more than I wanted to handle. But the 21 lb weight of the 9.25" OTA should be quite manageable on the GM8, and doesn't exceed my self-imposed limit of no part heavier than 30 lbs. smile.gif
Anyone here have a similar set up?
I did have a 11" Celestron a few years back, but I decided that was somewhat awkward.
I know that new scopes are scarce right now. Hoping I might see one pop up on the used market.
Edited by Steve C., 07 May 2021 - 05:48 PM.
#2 junomike
junomike
  • Loc: Ontario
Posted 07 May 2021 - 05:59 PM
If you're not imaging and view with little wind, I'd go for the C925 Evo.  It will be far easier to set up and align and you'll most likely use it  more.
  • ewave and Bean614 like this
#3 gnowellsct
gnowellsct
Posted 09 May 2021 - 12:33 AM
I think it is true the Evo will be faster setup but I personally, as a stability freak, would avoid them like the plague.   And the other question is, will the Evo be working 20 years from now?   Can you add a refractor to it?  The 20 year old G11 below is still going....but it *is* more setup hassle.
Between the G8 and G11...there's so much more you can do with a G11.  (Like mount an apo.)  But there is sort of a half way measure which is get a GM811g on the HD tripod.   With that the bottom half of the EQ head is the G11.  But at that point I think you might as well get a G11.  Which is what I have thought about the G8s for a long time anyhow.
Greg N
Edited by gnowellsct, 09 May 2021 - 12:34 AM.
