8" or 10" Newtonian on an eq6r pro
Astrophotography DSO Equipment Imaging Reflector
3 replies to this topic
#1 KyeNelson
KyeNelson
Posted 08 May 2021 - 04:07 PM
I have seen many people use a 10" and even a 12" on an eq6r pro over on Astrobin.
Currently my telescope is a WO Z73 with an asi183mm.
I was wondering if the eq6r pro would be able to handle a 10" for imaging, or if I should go down to an 8". (Either the Orion 10" astrograph or the Sky Watcher Quattro 10")
Kye
#2 wizbang396
wizbang396
Posted 08 May 2021 - 05:12 PM
Check the weight capacity of the EQ6 and both scopes, that will tell you if they will work.
#3 sbradley07
sbradley07
  • Loc: Connecticut
Posted 08 May 2021 - 05:19 PM
Moving to Mounts forum for better fit.
#4 AhBok
AhBok
  • Loc: Lakeland, TN
Posted 08 May 2021 - 08:17 PM
I imaged with an 8” F4 newt on my EQ6R Pro mount for about 2 years. I considered it to be the limit for imaging. The main problem was the slightest breeze turned the OTA into a sail with just a 3-5 mph breeze. Intermittent breezes were the worst. I now have both a 6” RC and 72mm Apo mounted on my EQ6R Pro and it is far more stable.
Edited by AhBok, 09 May 2021 - 02:31 PM.
  • mikefulb likes this
Also tagged with one or more of these keywords: Astrophotography, DSO, Equipment, Imaging, Reflector
