scope or camera
4 replies to this topic
#1 garyc11
garyc11
  • Loc: lockport,ny
Posted 09 May 2021 - 10:56 AM
I have a evolution 6 and a zwo 224 do you think the zwo 178 would work better for deep sky?
i am also looking at the 6 in f/4 imaging newt to use with the 224.
cant afford both so should i get the camera or the newt. I could go up to around $500 if there is a better option.
#2 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 09 May 2021 - 01:09 PM
If you are talking about the colour 178 sensor, I believe the 224MC is more sensitive. Will it work better for you may depend on whether you want a slightly larger sensor with higher resolution (the 178), or a more sensitive sensor (the 224).
You could use your C6 with focal reduction instead of the fast Newt. I use twin f/6.3 reducers on my C6 and C8 to get to around f/4 with a small sensor camera, or you could use a single reducer with your C6.
#3 GazingOli
GazingOli
  • Loc: Stuttgart GERMANY
Posted 09 May 2021 - 03:06 PM
I found out that the ASI178MM works exceptionally well for galaxies with my C8 @f/6.3, much better than the ASI224. Maybe you want to try with B&W for galaxies.
I also got the ASI178MC but still testing. Went very well for M57 last night, but need to do more testing.
Last night I also did a direct comparison of the MM and MC at Messier 90. But I am traveling right now and will be back only tomorrow and post the results.
CS.Oli
Edited by GazingOli, 09 May 2021 - 03:07 PM.
#4 GazingOli
GazingOli
Posted 10 May 2021 - 04:02 AM
as promised my examples from the night of May 8-9, 2021:
M 90 with C8 @f6.3 camera ASI178MC 52 frames x 8 sec resized
more settings:
[ZWO ASI178MC]
Binning=1
Capture Area=3096x2080
Colour Space=RAW8
Temperature=17
Hardware Binning=Off
Gain=400
Exposure=8
White Bal (B)=90
White Bal ®=70
Brightness=200 (maybe too much?)
Auto Exp Max Gain=255
Auto Exp Max Exp M S=30000
Auto Exp Target Brightness=100
Mono Bin=Off
Banding Threshold=35
Banding Suppression=0
Apply Flat=None
Subtract Dark=C:\...\darks\ZWO ASI178MC\RAW8@3096x2080\8,0s\gain_400\dark_20_frames_20,6C_2021-04-15T19_10_43.png
M 90 with C8 @f6.3 camera ASI178MM 51 frames x 8 sec resized
more settings:
[ZWO ASI178MM]
Binning=1
Colour Space=MONO8
Temperature=17,7
Gain=300
Exposure=8
Brightness=100
Auto Exp Max Gain=300
Auto Exp Target Brightness=101
Apply Flat=None
Subtract Dark=C:\...\darks\ZWO ASI178MM\MONO8@3096x2080\8,0s\gain_300\dark_20_frames_9,8C_2020-11-20T21_59_25.fits
screenshot:
CS.Oli
Edited by GazingOli, 10 May 2021 - 10:11 AM.
  • roelb likes this
#5 garyc11
garyc11
  • Loc: lockport,ny
Posted 10 May 2021 - 03:34 PM
nice images,
thanks
