Redcat Tilt and Coolmination issues
3 replies to this topic
#1 Dalemazkour
Dalemazkour
Posted 09 May 2021 - 12:09 PM
Here are the 4 corners of my redcat from last night and what CCD inspector shows.  I dont have alot of space to adjust the tilt in between the 2600mm camera/Filter Wheel and Redcat tilt plate. I would have to purchase additional adapters to reach backfocus for tilt adjustments. See picture showing image train..
Is this normal or do I need to ask for an exchange? I really like the potential of the redcat but this is unacceptable for a $1000 telescope to not to be at least coolminated prior to shipping. I can make adjustments if you guys have suggestions. Only a year into this hobby so I don't have much experience with adjustments as usually the scopes I have used like the ES127 CF I dont have noticeable coolmination and tilt issues. I appreciate feedback from others who have been able resolve with the redcat or similar setup.
#2 dan_hm
dan_hm
  • Loc: New Jersey
Posted 09 May 2021 - 12:32 PM
Like I said in the other thread the 4 corners picture is too small to get any idea of what's going on. You'll need to share a higher resolution picture.
The tilt in CCD Inspector indeed looks pretty severe, but I can tell just by looking at the picture of your imaging train that the camera isn't sitting flush against the filter wheel. That alone is going to cause tilt.
#3 Gleason
Gleason
  • Loc: SF Bay Area
Posted 09 May 2021 - 12:34 PM
It's most likely the camera array that is slightly tilted, not the RedCat.  Common problem. Does not ZWO camera have built in tip-tilt adjustments?
#4 acommonsoul
acommonsoul
  • Loc: Hacienda Heights, Ca
Posted 10 May 2021 - 08:24 AM
Did you have this issue with another camera connected? Or just the ASI2600? Post the pic on astrobin and link it for us to look at in full res. I will say that my first Redcat had an issue with one of its lenses. WO ended up replacing it for me after I sent the scope back to them.
Edited by acommonsoul, 10 May 2021 - 08:26 AM.
