APO Tri or Quad Suggestion for Astrophotography
Astrophotography Beginner
7 replies to this topic
#1 ruamaya
ruamaya
Posted 09 May 2021 - 01:42 PM
Hey everyone,
I am looking for an Refractor APO, either tri or quad, for astrophotography. Currently have a reflector telescope but wishing for a wider FOV. Any suggestions in the $1000 to $2000 range. Much appreciated.
#2 ZL4PLM
ZL4PLM
    Vendor Affiliate - ZWO Product Dev Team Member
  • Vendor Affiliate
  • Loc: Darfield, New Zealand
Posted 09 May 2021 - 02:01 PM
Askar FRA400 and focal reducer - lovely wide field pin point stars and crisp image - def recommended here
  • DRK73 and bobzeq25 like this
#3 calypsob
calypsob
  • Loc: Virginia
Posted 09 May 2021 - 02:07 PM
The 76 EDPH and 94 EDPH both do really well with their dedicated reducers.  I own the 76
Here is the 76 with an APS-C ASI 2600mc . Spacing is maybe 98% perfect
50600849901_dbf81a37b9_c.jpgAbberation Inspector - ASI 2600MC - Sharpstar 76 EDPH by Wes, on Flickr
Here is the entire image from the 2600mc
50447292063_0ed7336326_z.jpgMBM 54 by Wes, on Flickr
Here is Sony A7RIII Full frame. Spacing is not optimized and the t adapter obstructs the sensor at the edges.
50587790932_defb56cca9_z.jpgAbberation Inspector of Sony/76EDPH by Wes, on Flickr
Here is the entire frame from the Sony
50587790862_1431d86f90_z.jpgSharpstar 76 EDPH with Reducer and Sony A7RIII by Wes, on Flickr
  • bobzeq25 and limeyx like this
#4 bobzeq25
bobzeq25
Posted 09 May 2021 - 02:12 PM
I have a Stellarvue version of this, which I believe they no longer sell.
https://www.teleskop...ertificate.html
https://www.teleskop...f-6-CF-Apo.html
Sample image below, better version here, with acquisition details.  Atik 460 EXM CCD.  FOV about 2 X 1.5.  My new 2600 camera would have captured the whole nebula.
https://www.astrobin.com/285813/B/
Another possibility, similar focal length, integral flattener, which is very convenient.
https://agenaastro.c...-refractor.html
Similar scopes to both above, of various quality, are sold under a number of labels.  I picked these as excellent quality.
Edited by bobzeq25, 09 May 2021 - 02:15 PM.
#5 EdDixon
EdDixon
  • Loc: Virginia
Posted 10 May 2021 - 05:07 AM
William Optics scopes are very good quality units.  Their GT81 is a triplet and goes for about 1500 USD.  THe flattener adds another $238 or so.  A couple of the online firms have them in stock.
  • bobzeq25 likes this
#6 ruamaya
ruamaya
Posted 11 May 2021 - 11:11 AM
Thanks everyone so far for your suggestions and advice.
#7 asanmax
asanmax
    Vendor - DSLR Modifications
  • Loc: Vancouver BC
Posted 11 May 2021 - 11:38 AM
If you're looking for wider field of view, then some information about your camera sensor size would help a lot in determining the best FL of the scope.
You should be looking for the best match for your camera sensor size in terms of arcsec/pixel ratio.
Here is the calculator:
https://astronomy.to...calculators/ccd
Best ratio is typically 1-2 arcsec/pixel.
Quadruplets/pentuplets are a bit easier to use. But a good pair of a triplet and flattener or flattener/reducer will be producing amazing images as well.
Look for FPL53 or FCD-100 glass if you can afford those.
#8 tjz
tjz
  • Loc: Colorado Springs, CO
Posted 11 May 2021 - 02:10 PM
If you want wide-field, I would highly recommend the WO Redcat series. The Petzval design gives a nice flat field out to at least an APS-C sized sensor. I do see some edge deterioration on a full-frame sensor.
Here's an example of what you can squeeze into that nice wide field: https://astrob.in/1kcp6u/0/
I've added a DeepSky Dad / ZWO EAF kit for auto-focus and it is a solid and enjoyable piece of gear. I love it!
Also tagged with one or more of these keywords: Astrophotography, Beginner
