An AVX Curiosity
23 replies to this topic
#1 desertstars
desertstars
  • Loc: Tucson, AZ
Posted 09 May 2021 - 06:36 PM
In 2019 I upgraded the Three-legged Newt to a Celestron AVX mount. While the alignment process ultimately proved easy enough to learn, I never seemed to achieve especially impressive accuracy when using that alignment to locate objects. Selected objects (including calibration stars) were consistently at the very edge of the field of view (using a finder eyepiece with a 1.4 degree TFOV) I've done enough polar alignments for visual observing to discount polar alignment as the source of the this displacement. A minor annoyance, but an annoyance all the same.
Because I use the Newt in more than one location, I decided to purchase a Celestron SkySync GPS device and let technology handle a couple of set-up and alignment chores - time and place. (Yes, I'm that lazy. wink.gif ) The persistent displacement during alignment and calibration was immediately reduced to an amount I now consider trivial. Selected objects for observation land well within that 1.4 degree TFOV, requiring a modest tweak at most to center the object. I've done nothing else different, so feel safe assuming cause-and-effect here.
So, I'm assuming the use of the SkySync brought this about. Am I off base thinking that my distance from the standard meridian for Mountain Standard Time (105 degrees west for MST, 110.98 W. for my location in Tucson) is sufficient to create the displacement I first saw? And that a GPS fix for where (and when) I am when I observe did, in fact, provide a measure of correction?
The kind of stuff you don't absolutely need to know to use the gear, but can't help wondering about.
#2 ButterFly
ButterFly
Posted 09 May 2021 - 07:18 PM
Time, location, and polar alignmnet are irrelevant for star alignment.  Time and locaion matter for planets.  Polar alignment matters for tracking.  Whatever it was, it was something else.
You should be aiming for less than 15 minutes of error.  Entirely reasonable with the AVX if you aim at the correct stars and nothing slips.  Check the tightness of your clutches.
  • desertstars and SkipW like this
#3 WadeH237
WadeH237
  • Loc: Ellensburg, WA
Posted 10 May 2021 - 10:57 AM
If I had to guess, I would say that SkySync is doing a better job of aligning to the sky.
The first thing that comes to mind for me, is that there is a technique to get the stars centered correctly for alignment.  Specifically, you need to always to the final centering of the alignment and calibration stars using only the "up" and "right" keys on the hand controller.  When I align a NexStar mount, I always first center the star in the eyepiece, and then I use the "down" and "left" keys to push it to the edge of the field.  I can then use only "up" and "right" to center it.  This ensures that any backlash (and the AVX has quite a bit) is always taken up in the same way when you center the star.
If you don't center the stars that way, pointing accuracy will suffer.
  • desertstars and MichoFreakshow like this
#4 desertstars
desertstars
  • Loc: Tucson, AZ
Posted 10 May 2021 - 02:03 PM
That trick was explained to me when I bought the mount at Starizona. It's SOP when I use the mount. cool.gif
  • MichoFreakshow likes this
#5 KJL
KJL
  • Loc: Boston, MA
Posted 10 May 2021 - 02:21 PM
And, besides, SkySync doesn't do alignment, just time and location.
Out of curiosity, how did you enter your location into your AVX prior to acquiring the SkySync?
  • desertstars likes this
#6 desertstars
desertstars
  • Loc: Tucson, AZ
Posted 10 May 2021 - 03:49 PM
Correct. There are numerous one star reviews out there for this devise because people somehow don't get this. Go figure. I thought the product description was clear enough on the matter. shrug.gif
When it was set up for me, local time from someone's watch was used in the store, and I believe a location was selected from a menu. (I may not be remembering the source correctly.) The location was a nearby Air Force base. In learning how to use the mount, I redid the location using coordinates for my home obtained via Google Maps and used local time displayed on the laptop I sometimes use for astronomical purposes. Did the same to change the location on the first trip to a dark sky site, half an hour north of home. I had comparable results in all three cases.
#7 KJL
KJL
  • Loc: Boston, MA
Posted 10 May 2021 - 04:28 PM
And in all three cases, you then used something like the Two Star Align for the calibration? Not, in particular, Quick-Align (which doesn't use stars at all).
In other words, even though you had centered the calibration stars during whichever alignment procedure you chose, the scope would still put objects to one side of the 1.4-degree FOV?
#8 desertstars
desertstars
  • Loc: Tucson, AZ
Posted 10 May 2021 - 06:26 PM
Yes. Two star alignment, with two calibration stars. I also made sure - having been advised to do so - that there were stars both east and west of the meridian used in the process. The results were consistent, with the objects invariably turning up just inside the described FOV. I accepted it because I was still getting where I needed to be, and tracking seemed unaffected.
In an earlier conversation on the forum, someone even told me this was simply to be expected. I found that odd, quite frankly. But I was able to work with situation, so I let it go at the time.
  • KJL likes this
#9 WadeH237
WadeH237
Posted 10 May 2021 - 06:37 PM
Sorry, my eyes read "SkySync" and my brain registered "StarSense"...
I can't offer any explanation for improved pointing with it.  The location and date/time information is used for pointing at the first two alignment stars, and also for pointing at the sun, moon and planets.  Pointing at deep sky objects is only dependent on the alignment and calibration stars.  The time and location could be completely wrong, but if you do the 2+4 correctly (understanding that you may need a big slew to hit the first alignment star), it will still point fine at deep sky objects.
  • desertstars and KJL like this
#10 desertstars
desertstars
  • Loc: Tucson, AZ
Posted 10 May 2021 - 06:45 PM
Of course, this matter isn't exactly a worrisome situation, a problem to be solved. I'm just at a loss to explain why the change I experienced occurred at all. My hypothesis does not seem to being holding up all that well.
#11 KJL
KJL
  • Loc: Boston, MA
Posted 10 May 2021 - 06:46 PM
A mystery.
By any chance is your AVX up-to-date? Perhaps there was a location/time bug in the firmware that was papered-over when you started using the SkySync?
For example, do you still have the issue when you remove the SkySync?
#12 desertstars
desertstars
  • Loc: Tucson, AZ
Posted 10 May 2021 - 06:50 PM
A mystery.
The last time I checked Celestron, no new firmware updates were waiting for me. I have not, however, used the AVX without the SkySync installed since I bought the device. I'll have to run the AVX without it next time out and see what happens. Next time out will be Thursday night, if the weather cooperates.
  • KJL likes this
#13 Wildetelescope
Wildetelescope
  • Loc: Maryland
Posted 10 May 2021 - 07:15 PM
betting your time is more accurate than reading off the computer and entering it.   Simplest explanation I can think of.  In any event, you are rocking and rolling now!  Have fun!
JMD
#14 mikewayne3
mikewayne3
  • Loc: San Diego CA
Posted 12 May 2021 - 11:59 AM
I have a question
Why don't you do a full 2+4 star calibration?
I love my AVX but I always do a 2+4 star alignment and with each star the pointing get better.
By the 3rd cal. Star it's close to center and after all 4 my goto's are dead on.
  • desertstars and bthrel like this
#15 desertstars
desertstars
  • Loc: Tucson, AZ
Posted 12 May 2021 - 04:31 PM
I have a question
I know I used more than 2 calibration stars early on, but I don't recall that it made much difference. I left it at 2+2 when I saw the change in results described above. I was getting objects in the field of view, after all. Even improved as things are, goto results have never been "dead on." I'll have the scope out under dark skies tomorrow night, and will do a 2+4 to see what happens.
#16 mikewayne3
mikewayne3
  • Loc: San Diego CA
Posted 12 May 2021 - 05:19 PM
Just to let you know.
First I do polar alignment with a Meade DSI then I switch to a DSLR, focus the camera and then do the 2+4 star alignment and by the 2nd calibration star I don't need to look through the finder scope and so on good luck tomorrow.
#17 KJL
KJL
  • Loc: Boston, MA
Posted 12 May 2021 - 09:43 PM
I look forward to the results of both 2+4 and your original method of 2+2 with SkySync out of the loop.
An interesting puzzle.
#18 ButterFly
ButterFly
Posted 13 May 2021 - 07:00 AM
If it persists, do a factory reset from the handcontroller.  I've had that solve quite a few mysteries with the AVX.  You have the GPS unit anyway, so it's not too much of a hassle.  Backup you PEC curve, if any, just in case.
#19 desertstars
desertstars
  • Loc: Tucson, AZ
Posted 15 May 2021 - 03:37 PM
Had this rig out under dark skies a couple of days ago, and did a couple of experiment.
The usual 2 star + 2 calibration stars definitely works better with the SkySync module active. Targets sought after alignment land about a third of the way from the center to the edge of the FOV with the module, and very near the edge without it.
I obtained moderately improved results repeating the experiment with a 2+4 alignment. The targets were never completely centered, but the improvement was such that I'll go with the 2x4 from now on.
As for other bits of advice, bear in mind that the polar alignment I do involves eyeballs and a compass. Being a visual observer, rather than an imager, I've never bothered with anything more precise.
By that point in the evening it was dark enough for serious observing, so I never got around to a factory reset. Perhaps next time out.
"Curiouser and curiouser!"
#20 ButterFly
ButterFly
Posted 15 May 2021 - 08:07 PM
Same here.  I just plop it down Northishly, then use the latitude scale.  It gets me tracking for a few minutes in the eyepiece, so it's fine.  But again, the star alignment knows how far off your polar alignment is, and takes that into account when pointing.  You can read off the measured polar alignment error and the local sidereal time, after a star alignment.  You can also use that to polar align the mount after a star alignment.  The better your star alignment, the better that polar alignment can get.
In practice, if I'm several degrees off on both axes, I'll bother to fix it.  One or two degrees on each is managable at the eyepiece.  Go through the handcontroller's all-star polar alignment just once to see what's involved.  Then decide for yourself what sort of errors are worth your trouble to fix.  The longer the focal length of the scope, the more it becomes worth it.
Edited by ButterFly, 15 May 2021 - 08:08 PM.
#21 desertstars
desertstars
  • Loc: Tucson, AZ
Posted 16 May 2021 - 08:35 AM
That's really the bottom line for me. The results I'm getting are a little better than good enough, so I'm satisfied. Just curious about the way things work, and why. Sometimes there's an "Oh, of course!" answer to these things. Others, you just get back to observing.
#22 drt
drt
  • Loc: Venice, Florida
Posted 20 May 2021 - 10:06 AM
Does anyone used Meade LX85 AC power adapter with Celestron AVX?
#23 DuncanM
DuncanM
  • Loc: Arizona Sky Village or the rain forest
Posted 20 May 2021 - 11:37 AM
It's essential to use a crosshair EP to precisely centre each of the 2+4 alignment stars. Accurate PA is not required for good pointing accuracy. Here's what's possible:
https://www.cloudyni...t/#entry7099140
#24 WadeH237
WadeH237
Posted 20 May 2021 - 02:07 PM
I don't use an illuminated reticule eyepiece.
I just defocus the alignment or calibration star so that it's a big donut (or big circle, in the case of an unobstructed scope).  If the star is defocused enough to fill a significant part of the field of view, then it's pretty easy to center it.  The key is that your eye is much better at detecting concentric circles (the circular star, centered in the eyepiece's field stop) than it is at detecting whether a pinpoint is centered in a large field.
Certainly, there is nothing wrong with using a reticule eyepiece.  It's just not necessary to buy one solely to align the mount.
  • ButterFly likes this
