Polemaster file locations
2 replies to this topic
#1 osbourne one-nil
osbourne one-nil
  • Loc: Cumbria, England 54.5ºN 2.5ºW
Posted 12 May 2021 - 02:15 AM
I've recently got a Polemaster and although I've only used it once, it seems to work great.
One niggle I have is when I go to connect, I always get a message saying "Cannot open file C:\blahblahblah\Polemaster\logs"
I can click "ok" but then the camera doesn't fire up.
The file location is gives in in a folder I sync with Dropbox; if I turn dropbox off, the message doesn't appear and it all works fine. The folder the program is installed in is not affected by Dropbox.
Is there a way to change the location of these log files, or do I simply have to workaround this and turn dropbox off?
#2 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 12 May 2021 - 07:15 AM
Can you configure Dropbox so that the file location is not synced with Dropbox, which might allow you to still leave Dropbox  running?
  • osbourne one-nil likes this
#3 osbourne one-nil
osbourne one-nil
Posted 12 May 2021 - 10:14 AM
I think I've tried that but will go back into preferences and check. To be honest, Dropbox is a bit of a pain and I'm not sure is worth the hassle with the laptop!
Thanks for the suggestion...I'll try again.
