What's causing this uniform artifact ?
CMOS Collimation DSO EAA Optics Reflector
8 replies to this topic
#1 GaryShaw
GaryShaw
  • Loc: Massachusetts / Wyoming
Posted 12 May 2021 - 12:27 PM
Hi:
Last night we finally had a clear-ish late evening sky - SQM 18.79.  I noticed M63, an old friend, was well positioned  so I moved in for some time with it.
Skies seemed clear but it was windy - 10-15 mph and gusty I estimate. I was running flats and darks and messed with the histo to the best of my ability but I could not remove the noise(?) pattern you see in this cropped image. I've begun using a TG 365 cover on the mount/scope and noticed the collimate knobs had loosened - probably from friction with the cover as I remove and replace it. Doesn't seem like a collimation thing but I plan to re-collimate and tighten all the adjusters so there's more tension holding them where I leave them. Unfortunately they protrude from the back end of the carbon fiber tube of the TS scope - talking with TS about that.
Anyway, please click to enlarge and have a look. Share any ideas you have on what causes this.
Many thanks!
Gary
M63 Sunflower Galaxy: ASI 294 MC, 71 frames/ 8 sec/ 300 gain/ 203mm F4 Newtonian
#2 Dynan
Dynan
  • Loc: NOLA
Posted 12 May 2021 - 12:46 PM
Are you dithering? Looks like it could be walking noise.
#3 GaryShaw
GaryShaw
Posted 12 May 2021 - 12:59 PM
Hi
No dithering. I’m just observing live with a camera ….EAA
What causes walking noise?
thank you
Gary
#4 SanjeevJoshi
SanjeevJoshi
  • Loc: Los Altos CA
Posted 12 May 2021 - 01:19 PM
Any chance you had upper atmosphere thin clouds? reminds me of how some of my images look when observing thru thin clouds.   Seems like a clear enough night but thats because the set up can punch thru clouds, although the view quality suffers on details a bit for objects other than stars.  What was the FHWM level roughly in Sharpcap?
Assuming proper process for flats and darks, the only other question would be about the flat.
How does the exposure and gain you used for the flat compare with the exposure and gain you used for the EAA in Sharpcap?
Edited by SanjeevJoshi, 12 May 2021 - 01:34 PM.
#5 Dynan
Dynan
  • Loc: NOLA
Posted 12 May 2021 - 01:56 PM
Fixed pattern noise in a sensor repeatedly appearing in the (nearly) same spot causes the pattern similar to what you're seeing. It MAY be the cause. Dithering removes this by moving the exposure on the sensor by a small amount, either every frame, or every nth frame.
  • GaryShaw likes this
#6 Rickster
Rickster
  • Loc: NC Kansas Bortle 3 SQM 21.8+
Posted 12 May 2021 - 03:24 PM
Looks atmospheric to me.  I take it that you have never seen this before?
#7 GaryShaw
GaryShaw
Posted 12 May 2021 - 03:47 PM
Rick, I’ve seen a variety of speckled, splotchy patterns in images but never really categorized them to recognize similar instances later on … guess I should do that once I have knowledge of what the causes and cures are for various patterns.
thank you
Gary
#8 bips3453
bips3453
  • Loc: MN
Posted 12 May 2021 - 04:28 PM
That is the inter-galactic cosmic web! ;-)
#9 Rickster
Rickster
Posted 12 May 2021 - 09:54 PM
thank you
Gary
I am the same way.  I know I have seen that pattern on numerous occasions, but I have not kept track of what I thought caused it at the time.
Also tagged with one or more of these keywords: CMOS, Collimation, DSO, EAA, Optics, Reflector
