NGC5981, NGC5982, NGC5985 (Draco Galaxy Triplet), Draco
Astrophotography CCD CMOS DSLR DSO Imaging Meade Orion Reflector SCT
10 replies to this topic
#1 rekokich
rekokich
  • Loc: Virginia
Posted 12 May 2021 - 12:40 PM
Image details:
-Meade 8'' ACF telescope, AP 0.7x telecompressor, 200x1400mm
-Canon T3i modified camera, Astronomik L3 filter
-iEQ30pro mount, Orion 60mm f4 SSAGpro autoguider
-31 x 300 sec subexposures, 5 discarded, iso1600, processed with 30 dark and 30 bias frames
-Software: PHD2, DSS, Xniew, StarNet++, and StarTools v 1.3 and 1.7
Thank you for looking.
Edited by rekokich, 12 May 2021 - 12:41 PM.
  • Jim Thommes, Magellanico, George Simon and 18 others like this
#2 rekokich
rekokich
  • Loc: Virginia
Posted 12 May 2021 - 12:44 PM
This less well known galaxy triplet is composed of NGC5985, NGC5982, and NGC5981. The first two members were discovered by William Herschel in 1788, while the third, smaller member was first reported in 1850 by J.Stoney, working with Earl of Rosse's 72 inch reflector. Similar redshift based distances suggest the three galaxies form a loose gravitational association. However, they are not catalogued as a "compact group" because they do not manifest conspicuous morphological or kinematic peculiarities, or evidence of starburst activity caused by close tidal interactions. The triplet lies in a field strewn with small, remote galaxies, most of which have no identifier, and none of which have documented redshifts in SIMBAD and NED databases. NGC5976, a distant lenticular galaxy, is the most prominent of these background galaxies. Unfortunately, in the absence of redshift data it is not possible to estimate its distance and physical properties.
NGC5985 is a nearly face-on barred spiral galaxy of morphological type SBbc. Spectroscopy of its nuclear region in visible and infrared light reveals bright emission lines of hydrogen, helium, nitrogen, and oxygen, suggesting an active galactic nucleus (AGN) of the Seyfert type. Such nuclei are powered by accretion disks around central supermassive black holes. Since the nucleus is obscured by gas and dust, it does not appear prominent in the visible band, but it exceeds in brightness the rest of the galaxy in the infrared. Hairlike streamers of luminous matter arise from the western spiral arm, possibly drawn out during a distant gravitational interaction with a neighboring galaxy. Based on its measurable properties (redshift, apparent magnitude, angular diameter), NGC5985 is about 150,000 light years in diameter, 0.37 times the brightness of the Milky Way, and lies at a distance of 116 million light years, receding at 2,499 km/s.
NGC5982 is an elliptical galaxy of the E3 morphological type. It also has an AGN with a LINER region (low-ionization nuclear emission-line region) powered by a central supermassive black hole estimated at 830 million solar masses. Spectroscopic studies reveal that the nucleus is kinematically decoupled from the galactic envelope, rotating at nearly 90* relative to the rest of the galaxy. Infrared photography reveals that the envelope is composed of at least 24 well defined shells of gas and dust distribution. These features are thought to be a result of several galaxy mergers. Based on its measurable properties, we can estimate NGC5982 to be 192,000 light years in diameter, roughly as bright as the Milky Way, and to lie at a distance of 133.4 million light years, receding at 2,882 km/s.
NGC5981 is a smaller spiral galaxy seen from the edge-on perspective. It has a lower new star formation rate than expected. This is presumably due to a large dark matter halo which quenches new star formation through a process called "virial shock heating", whereby surrounding gas descends into the galaxy too rapidly to allow for sufficient cooling and condensation into stars. The galaxy is about 100,000 light years in diameter, one eighth the brightness of the Milky Way, and lies at a distance of 120 million light years, receding from us at 2,579 km/s due to the expansion of the Universe.
Perhaps the most remarkable object in the field is quasar SDSS J153753.97+593114.2. SIMBAD database lists its apparent magnitude as 19.1 (g), but it looks much brighter on the photograph. DSS2 sky survey lists the object's apparent magnitude as 17.3. Redshift of 2.219 indicates light travel distance of about 10.72 billion light years and relativistic recession velocity of 247,021 km/s (at the time the light we now observe was emitted). In the present epoch, its proper distance is 18.06 billion light years, well beyond the cosmic event horizon, and its proper recession velocity is superluminal at 390,148 km/s. The light the quasar is presently emitting can never reach us. Assuming apparent magnitude of 17.3 and no gravitational lensing, the quasar's absolute magnitude is -30.69, about 9,000 times brighter in the visible band than the entire Milky Way galaxy.
  • mrowlands, zakry3323, Hondo and 2 others like this
#3 markbc
markbc
  • Loc: Pacific Grove, CA
Posted 12 May 2021 - 01:34 PM
So Dr. J. Stoney discovered this in 1850! That's two years before the NGC list organizer J.L.E. Dreyer was born!
(I had thought Dreyer was one of the "discoverers").
Thank you for wonderful, annotated astrophotography and learning at the same time! wink.gif
  • rekokich likes this
#4 droe
droe
  • Loc: Fenton, Mi
Posted 12 May 2021 - 09:26 PM
That is a beautiful target. Great job, I got to put that one on my list.
#5 zakry3323
zakry3323
  • Loc: Fairfield, Westmoreland County, PA
Posted 13 May 2021 - 07:18 AM
This is definitely going on my list for an attempt with the Edge8 and the ASI071. Beautiful capture and processing. I also really appreciate the annotation, did you use Star Tools to make the annotation or something else?
#6 rekokich
rekokich
  • Loc: Virginia
Posted 13 May 2021 - 12:28 PM
Thank you, Zakry.
The annotation was made with XnView. The chart is a negative of a screenshot, cropped and resized with XnView, then added to the bottom of the annotated image with XnView and/or MS Paint.
  • zakry3323 likes this
#7 zakry3323
zakry3323
Posted 13 May 2021 - 12:39 PM
Thank you, Zakry.
Sounds simple, but looks elegant. Thanks for the explanation!
#8 elmiko
elmiko
  • Loc: Arizona
Posted 13 May 2021 - 05:06 PM
Nice image! Color is beautiful!
#9 Jim Thommes
Jim Thommes
  • Loc: San DiegoCA USA
Posted 14 May 2021 - 08:28 PM
Great image and info - especially on the quasar. I have been keeping an eye out for quasars in my images. I have been intrigued with some quasars that have high red shift (and large tight travel time) but are relatively brighter than I would have expected.
#10 rekokich
rekokich
  • Loc: Virginia
Posted 15 May 2021 - 01:31 PM
Thank you, Jim.
I also have an interest in quasars. My initial impression was that they are accessible only to the professionals. I was fascinated to discover it is possible to photograph nearly to the beginning of the Universe with very modest amateur equipment. The most distant quasar I photographed so far is APM 8279+5255, with a redshift of 3.911. That corresponds to lookback time = light travel time of 12.1 billion years.
Quasar magnitudes can be quite variable, up to 3-4 magnitudes over a period of years. Reported photometry data can quickly become outdated.
https://www.cloudyni...d-quasars-r3233
#11 Jim Thommes
Jim Thommes
Posted 15 May 2021 - 08:52 PM
Thank you, Jim.
Yeah, that's a good catch!  I have read that capturing these high redshift quasars is quite the challenge with visual wavelength sensors. As I understood, what we "see" in the visible spectrum is the Lyman-Alpha emission at 121 nm wavelength. (which is single electron Hydrogen emission) So your 3.911 redshift was likely lyman-alpha shifted to 473.23 nm - so its a lyman-alpha emitter (LAE). It gets harder and harder for our amateur sensors to see lyman-alpha when it gets redshifted past our CCD or CMOS sensors to get them.
Also tagged with one or more of these keywords: Astrophotography, CCD, CMOS, DSLR, DSO, Imaging, Meade, Orion, Reflector, SCT
