iOptron CEM60EC RA not moving
5 replies to this topic
#1 stryker66
stryker66
Posted 12 May 2021 - 08:43 PM
I was about to start imaging and RA slew not moving. DEC moves fine. This was fine 3 weeks ago, no error in hand controller. It behaves just like no cable attached. The hand controller does show like it is slewing. You guys think its an RA board issue? Is there a way to do a factory reset on this mount? thanks.
I checked my receipt and this was purchased May 15, 2020 at highpointscientific so I think it is still under warranty.
Edited by stryker66, 12 May 2021 - 08:51 PM.
#2 RossW
RossW
  • Loc: Lake Biwa, Japan
Posted 13 May 2021 - 07:58 AM
Is it making a loud noise like the stepper motor is cogging?
Check that you have removed the RA locking pin.
Check that the RA clutch is engaged.
It might be the RA stepper is faulty and needs replacing. Or the RA board as you mentioned.
Good luck.
#3 stryker66
stryker66
Posted 13 May 2021 - 10:59 AM
no noise at all, no hum and completely silent, unlike DEC. Firmware upgrade works on all RA, DEC and main board and HC. Similar to this thread..
https://www.cloudyni...drive-troubles/
#4 Der_Pit
Der_Pit
  • Loc: La Palma
Posted 14 May 2021 - 06:28 AM
I'd open the RA board cover and check all connections/plugs there.  Could be a loose motor connector.  If not, -> iOptron support.
#5 stryker66
stryker66
Posted 14 May 2021 - 12:52 PM
I switch the board, I use the DEC board temporarily to make sure it is not the RA motor, and behold the RA is alive again and the issue moved to DEC. So 100% it is the RA board. waiting for RMA so they can ship a new RA board
  • RossW likes this
#6 stryker66
stryker66
Posted 18 May 2021 - 01:54 PM
I got the board today and problem is fixed..
  • Der_Pit likes this
