First light, Lunt 100 double-stack
7 replies to this topic
#1 hamers
hamers
  • Loc: Madison, WI
Posted 12 May 2021 - 09:02 PM
I'm on the very steep part of the learning curve on this.  After greatly enjoying  a Lunt LH100 front-mounted etalon on my Tak TSA-120, I decided to spring for a second etalon.  I had a little trouble getting all the electronics working today (USB  issues, etc) and then clouds were popping up all over the so in the end I only got a few decent iamges.  But it's a start. Fairly minimal processing as the seeing today didn't quite live up to what I had hoped.  FireCapture, best 15 frames stacked in Autostakkert, sharpened a little in Registaxx, final contrast in photoshop.Sun_123650_48_lapl2_ap6997_reg2 copy.jpg
Edited by hamers, 12 May 2021 - 09:38 PM.
  • rigel123, hopskipson, BinoGuy and 8 others like this
#2 astro rocketeer
astro rocketeer
  • Loc: Valencia, CA (Los Angeles)
Posted 12 May 2021 - 09:17 PM
Congrats on the Double Stack. Excellent Hamers!!
  • hamers likes this
#3 Stellar1
Stellar1
  • Loc: Ontario, Canada
Posted 12 May 2021 - 10:07 PM
That’s amazing! now wait a min, did you say you had a Lunt front mounted etalon on your 120? so can I put a front mounted etalon on my 102 making it an H-alpha scope? I assume I would need an ERF at the diagonal too? I didn’t know one could do this. Would it not be cheaper than buying a separate dedicated H alpha scope no? Hmm.
#4 jwestervelt
jwestervelt
  • Loc: Phoenix, Arizona
Posted 12 May 2021 - 10:12 PM
Lunt at one point did sell front-mounted etalons for attachment to third-party scopes.  You absolutely still need a blocking filter in addition, and those are not cheap.  An ERF may also be a requirement for larger apertures.
  • Stellar1 likes this
#5 Stellar1
Stellar1
Posted 12 May 2021 - 10:14 PM
I just came back to edit my query after realizing I forgot about the blocking filter, your post confirmed it, looks like it will be no less expensive at all.
  • hamers likes this
#6 hamers
hamers
  • Loc: Madison, WI
Posted 12 May 2021 - 10:41 PM
The Lunt 10cm etalon, to be front-mount on any scope, is still listed on their web site. It is probably not less expensive (maybe more expensive) than a dedicated solar telescope, but it takes up a lot less space in the dining room and all the peripherals can be immediately added or subtracted.  In my case, Lunt first supplied me with a 10cm etalon and an adapter the fit onto the end of my Tak. They did a beautiful job on that. At the time I was undecided about double-stack due ot the cost. But after using the single-stack, I decided i liked it enough to go with a double-stack.  As you are probably aware, every accessory for the Tak is expensive.  So by putting the etalon on my Tak instead of getting  a dedicated solar scope, I am able to easily switch back and forth and not be carrying around twice as much gear,  and I can use the Tak extender and reducer as desired, and not have to duplicate other accessories (Pegasus power-box, electronic focuser, etc).
I should also mention that i'm a scientist by training and for most of my career I've been building or modifying commercial optical and electronic instruments. It's what I enjoy doing.  Others may be more focused on the final image, but, for me 'getting there is half the fun'. So from a pure cost standpoint it might not make the most sense. But from an enjoyment/satisfaction standpoint, it does.  If I was retired ( just a few more years to go) I'd probably be building the OTA from scratch.
Edited by hamers, 12 May 2021 - 10:52 PM.
#7 HPaleske
HPaleske
Posted 12 May 2021 - 10:53 PM
beautiful picture. Singleetalon is a duty doublestack is the freestyle. It takes many attempts to tune the two etalons well, whereby one has it somewhat easier in the front area.
cs Harald
www.unigraphprom.de
  • hamers likes this
#8 hamers
hamers
  • Loc: Madison, WI
Posted 12 May 2021 - 11:02 PM
cs Harald
www.unigraphprom.de
Thanks!  The image is OK... seeing was not good. But like all things, success builds on success.     I love your unigraph images- they are truly amazing!
