AR2822 WL (High Res), CaK, HA | May 14th 2021
16 replies to this topic
#1 MalVeauX
MalVeauX
  • Loc: Florida
Posted 14 May 2021 - 10:39 AM
Hi all,
Stormed and rained so far this week, but this morning was clear, lower temps and pretty ok seeing conditions between gusts. AR2822 is still looking good with a nice penumbra around the spot in the photosphere and lots of interesting activity in the chromosphere and popping off little flares.
High Res Photosphere:
Moderate Res Chromosphere:
(Doh, mislabeled the wavelength.... sigh, lol, its 3934A)
Seeing Conditions:
Equipment:
120mm F10 Refractor (C6R masked)
2" Internal sub-aperture D-ERF (Baader Blue CCD-IR Block Filter) + Lunt CaK B1200 + 290MM sensor (CaK)
2" Internal sub-aperture D-ERF (Baader Red CCD-IR Block Filter) + HA Etalon + 2x 1.7A Blocking Filters + 290MM sensor (HA)
200mm F10 SCT + Full Aperture D-ERF
Baader Red CCD-IR Block Filter + Baader ND 3.0 Filter + 290MM sensor (Photosphere)
Very best,
Edited by MalVeauX, 14 May 2021 - 10:42 AM.
  • EricCCD, Magellanico, drprovi57 and 20 others like this
#2 PhotonJohn
PhotonJohn
  • Loc: Lake Ahern Observatory Viera Florida
Posted 14 May 2021 - 10:59 AM
Lovely set Marty, especially the CaK.
  • MalVeauX likes this
#3 HPaleske
HPaleske
Posted 14 May 2021 - 11:17 AM
Beautiful pictures, especially the first image I like it.
cs Harald
www.unigraphprom.de
#4 Mike G.
Mike G.
  • Loc: Oberlin, Ohio
Posted 14 May 2021 - 11:27 AM
fantastic Marty!
thanks for sharing
#5 EricCCD
EricCCD
Posted 14 May 2021 - 12:41 PM
#6 MAURITS
MAURITS
  • Loc: Belgium
Posted 14 May 2021 - 12:47 PM
Beautiful Marty.
#7 David Boulanger
David Boulanger
  • Loc: Naples, Florida
Posted 14 May 2021 - 01:44 PM
Very nice!!  Excuse my ignorance but what is this " sun scintillation monitor" ?  Where do I find this software?  Or is it more equipment I need while I seem to be always under budget in this telescope endevour.
#8 MalVeauX
MalVeauX
  • Loc: Florida
Posted 14 May 2021 - 01:49 PM
Hello,
The SSM is a device that uses IR light sampling and relates it indirectly to estimated atmospheric seeing conditions.
https://airylab.com/...lation-monitor/
The software is there, but it needs a device to operate. I use it to measure seeing so I know what my potential options are. In this case, I used it to get an idea of whether or not I could even attempt to use my 200mm aperture or not. So if you look at my 60 minutes of measurements there, my 1 min average is 1.2+ arc-seconds, which does not support 200mm aperture resolution. That is more closer to my 120mm aperture potential resolution, so I know I can image with 120mm aperture and have potentially good outcomes with lucky imaging. However, you'll notice peaks in seeing and I saw between my averages I would note seeing values around 0.7~0.8 arc-seconds (such as during the screen shot the current seeing was in this range) and seeing repeating peak moments like that, I can potentially lucky image with my 200mm in red wavelength at least, so I did that and was successful (lucky) with capturing some frames during a very brief moment of good sub-arc-second seeing. I image at 170 FPS so even half a second ensures me around 80~85 frames. That's lucky imaging!
Very best,
Edited by MalVeauX, 14 May 2021 - 01:53 PM.
  • David Boulanger likes this
#9 David Boulanger
David Boulanger
Posted 14 May 2021 - 02:38 PM
Thank you.  OPT sells the device.  Learn something new every day.
#10 dhkaiser
dhkaiser
Posted 14 May 2021 - 04:01 PM
Marty, very nice that you can use a 200mm aperture!
#11 R Botero
R Botero
  • Loc: Kent, England
Posted 15 May 2021 - 03:17 AM
Great images. Love the B&W CaK.
Roberto
#12 BeltofOrion
BeltofOrion
  • Loc: Newfoundland, Canada
Posted 15 May 2021 - 04:45 PM
Great set of imaes, Marty!
#13 lorenzo italy
lorenzo italy
  • Loc: Montichiari (Bs) Italy
Posted 16 May 2021 - 02:02 AM
Great photographs,
and good seeing.
The two things always go hand in hand.
Congratulations.
Lorenzo
#14 ch-viladrich
ch-viladrich
  • Loc: France
Posted 16 May 2021 - 04:59 AM
A very nice set of pictures Marty !
#15 Spot On
Spot On
  • Loc: San Francisco, CA
Posted 07 June 2021 - 02:42 PM
David, you can also build it for a lot less, it's only about $25 worth of parts if you're handy. :-) http://www.joachim-s...e/sssm_eng.html
  • MalVeauX and David Boulanger like this
#16 MalVeauX
MalVeauX
  • Loc: Florida
Posted 07 June 2021 - 04:20 PM
Indeed,
Dave has made his DIY:
https://www.cloudyni...d-is-my-seeing/
https://www.cloudyni...y#entry10844955
Very best,
  • Spot On likes this
#17 peterm
peterm
  • Loc: Gold Coast, Queensland, Australia
Posted 07 June 2021 - 04:25 PM
Super detailed images as usual Marty, well done!
