The Shortest F/L Eyepiece Ever?
37 replies to this topic
#1 HellsKitchen
HellsKitchen
  • Loc: Renmark, Australia
Posted 16 May 2021 - 09:39 AM
Is the Vixen 1.6mm the shortest focal length eyepiece ever made for the amateur market? What would one use such an eyepiece for? I have one, and my answer is for the moon and planetary nebulae, shall the weather ever improve. This year has been hideous.  Hopefully June brings the high pressure systems in gear with their freezing rock hard conditions. There was one night last year in July, where my 3mm Delite was not short enough.
Edited by HellsKitchen, 16 May 2021 - 09:42 AM.
  • Astrojensen and ziggeman like this
#2 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 16 May 2021 - 02:12 PM
  • SandyHouTex, Miranda2525, sanbai and 1 other like this
#3 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 16 May 2021 - 02:47 PM
I would love a 2mm Delite.
  • ShaulaB likes this
#4 HellsKitchen
HellsKitchen
Posted 16 May 2021 - 10:37 PM
It's fun to dream smile.gif  If TV came out with a 2mm Delite, I would be falling over myself running to the order button.
#5 Voyager 3
Voyager 3
  • Loc: Near Bangalore, India
Posted 16 May 2021 - 11:20 PM
Have you ever got the chance to try the HR Sab ?
#6 HellsKitchen
HellsKitchen
Posted 17 May 2021 - 12:22 AM
Nah, the weather over the last several months has been pure trash. Just endured the worst summer in history, nothing but cold fronts, jetstreams and absurd winds. This May is fast proving to be Southern Victorian, abnormal levels of clouds and that infernal wind. No stagnant high pressure to speak of. Hopefully June delivers.
Edited by HellsKitchen, 17 May 2021 - 03:18 AM.
  • Voyager 3 likes this
#7 Jon Isaacs
Posted 17 May 2021 - 04:06 AM
I use the 5 mm and 3.5 mm Naglers with a 2x Barlow n a regular basis, that's 2.5mm and 1.75 mm.
My scopes all track manually so a 1.6 mm with a 42° AFoV is not practical. I calculate the TFoV in my 10 inch F/5 to be 3.2" at 780x. The 3.5 mm + 2x Barlow + Paracorr provides 5.7" at 820x..
#8 izar187
izar187
  • Loc: 43N
Posted 17 May 2021 - 04:26 AM
For the 130mm perhaps?
And the 80mm(s) and 72mm I presume.
#9 Sarkikos
Sarkikos
  • Loc: Per sylvam ad astra
Posted 17 May 2021 - 07:21 AM
AFAIK, the 1.6 HR is the shortest focal length eyepiece that is commercially available.
I've used mine mostly in my fast to mid-range f-number refractors.   It is a good eyepiece for double stars.  I can also see using it for planetary nebulae.
I would not dare using the 1.6 HR for the Moon.  It would make my eye floaters unpleasantly obvious.  It's borderline for bright planets.
None of my mounts track.
What I'd really like to see is a 2.7mm Ethos-SX 110 degree!
Edited by Sarkikos, 17 May 2021 - 07:24 AM.
#10 25585
25585
  • Loc: In a valley, in the SW UK. Dark end of the street.
Posted 17 May 2021 - 08:01 AM
Barlow a 4mm.
#11 TayM57
TayM57
Posted 17 May 2021 - 08:27 AM
Barlow a 4mm.
My thoughts exacty. Powermate 2x + 4mm Delite = 2mm Delite. A 2mm Delite is one I wouldn't buy, given the limited use.
  • 25585 likes this
#12 Voyager 3
Voyager 3
Posted 17 May 2021 - 09:30 AM
Barlow a 4mm.
Or 1.25" PM a 5mm wink.gif .
#13 25585
25585
Posted 17 May 2021 - 10:13 AM
My shortest FL prime ep is a Vixen LV 2.5mm, but it hardly gets used. Mostly I Barlow zooms, having a TAL 4x Barlow, an 8-24 becomes a 2-6mm, so just right.
  • rkelley8493 likes this
#14 rkelley8493
rkelley8493
  • Loc: The Emerald Coast
Posted 17 May 2021 - 10:45 AM
I use a different route.. a convertible/variable barlow that yields about 3.5x at focus. With a 5mm eyepiece, the effective focal length is 1.43mm. However, the exit pupil is very small & dim, and floaters are a nuisance. 7.5mm [2.14mm effective FL] is usually as low as I go with the convertible barlow in the optical train.
#15 Sarkikos
Sarkikos
Posted 17 May 2021 - 10:51 AM
I have Barlows, but I hardly ever use them anymore.  In practice, I find it easier and faster to switch eyepieces rather than put in a Barlow plus an eyepiece, or worse, screw a Barlow assembly onto the barrel of an eyepiece.  And a shorter focal length eyepiece w/o Barlow tends to be lighter and more compact than a longer focal length eyepiece w/ Barlow.
But I can see several advantages to a Barlow:  (1) reduces the number of eyepieces you need to carry out with you, (2) reduces the number of eyepieces you need to buy, (3) can provide longer eye relief at higher power*, (4) can provide wider apparent and true fields of view at higher power*, (5) can improve the perceived optical performance of some eyepieces*.
* depending on the eyepiece you Barlow vs the eyepiece you would use w/o Barlow for the equivalent magnification
Edited by Sarkikos, 17 May 2021 - 11:41 AM.
  • izar187, HellsKitchen and rkelley8493 like this
#16 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 18 May 2021 - 06:20 AM
Sure, but sometimes it's the only solution available. A 2mm 82° eyepiece doesn't exist, for example.
Clear skies!
Thomas, Denmark
  • Sarkikos and eblanken like this
#17 Sarkikos
Sarkikos
Posted 18 May 2021 - 06:25 AM
Clear skies!
Thomas, Denmark
Yes, see #4 above.
But I'm still waiting for the 2.7mm Ethos-SX 110 degree!
:grin:
  • turtle86 and Astrojensen like this
#18 Astrojensen
Astrojensen
Posted 18 May 2021 - 06:48 AM
What would be sweet would be a 3.5mm, 3mm, 2.5mm and 2mm ES82's. I'm pretty sure they could make them by simply using different Smyth lenses on the existing 4.7mm.
Clear skies!
Thomas, Denmark
#19 Sarkikos
Sarkikos
Posted 18 May 2021 - 07:07 AM
There is a 2.5 Nagler.  But it has been discontinued.  I bought one used years ago, sold it, then later bought another.  I'm keeping this one.
  • Astrojensen and Paul Morow like this
#20 turtle86
turtle86
    Mr. Coffee
Posted 18 May 2021 - 07:45 AM
Yes, see #4 above.
Probably won't ever happen, since the 2.5mm Nagler was discontinued and a 2.7mm Ethos would be more expensive.  But if Televue ever changed its mind, I'd buy one in a heartbeat.
Edited by turtle86, 18 May 2021 - 07:46 AM.
  • Sarkikos and rkelley8493 like this
#21 junomike
junomike
  • Loc: Ontario
Posted 18 May 2021 - 02:30 PM
I'd like a 1mm eyepiece and then instead of changing EP's to obtain magnification, I'd just change OTA's. Makes for easier math grin.gif
  • Sarkikos, happycamperjohn, OneGear and 2 others like this
#22 CHASLX200
CHASLX200
Posted 18 May 2021 - 06:44 PM
Once i go over 1000x hand tracking a Dob is a job bob. Be nice if it was EQ mounted then ya just gotta deal with one motion.  600x and under i am fine with hand tracking.
#23 Gregrox
Gregrox
  • Loc: Peidmont Triad in NC
Posted 18 May 2021 - 07:24 PM
That reminds me of something Mel Bartels wrote in his Richest Field Telescopes page https://www.bbastrod...ns.com/rft.html
A final provocative thought...
Notice how the field of view is darker at higher magnifications? You can see more detail not only because the image is magnified but also because the background is darker. Do you ever stop the aperture down in order to darken the field at the given magnification? No?
Let's say you are observing Orion's Great Nebula, M42. And let's say that the magnification is set at say 100x. Would you choose a 6 inch scope with a darker background at this 100x or a 12 inch scope with a brighter background at 100x? Choose the 12 inch?
Then doesn't it follow that you should settle on a single eyepiece and a progression of apertures, say 6 inch, 12 inch and 24 inch?
Shoot, I mean, in a world where you can get acceptable OTAs for the same price or less as premium eyepieces...
#24 hoof
hoof
  • Loc: Monroe, WA
Posted 18 May 2021 - 07:44 PM
I’ve used my 2.4mm once on the moon on my 15” F/4.1, it’s the highest power I’ve gone on the moon ever and had the view be sharp. My 1.6 has been used to look at the double-double with my 80ED, the four stars looked like little discs. The 2.0 hasn’t really been used yet except for trying it out, I mostly got it to complete the set :) The 3.4mm gets used quite a bit, however.
Edited by hoof, 18 May 2021 - 07:45 PM.
#25 wrvond
wrvond
  • Loc: West Virginia
Posted 18 May 2021 - 09:37 PM
I use my 2.5mm Nagler with a 3x Barlow all the time.
  • eblanken likes this
