Where to buy ronchi film gratings nowadays?
17 replies to this topic
#1 Pokemoncrusher1
Pokemoncrusher1
Posted 17 May 2021 - 10:58 AM
Edmund is way too expensive, ronchiscreens is gone, willman bell is also gone, any other affordable alternatives? if not i guess im forced to buy a ronchi eyepice but id rather just diy it if I can.
#2 Pinbout
Pinbout
Posted 17 May 2021 - 11:00 AM
dm me
#3 black_rig
black_rig
Posted 20 May 2021 - 08:10 AM
Here is a way to get Ronchi screens for a few bucks: download the files and have them printed for a few bucks at one of the suggested online slide printers.
https://erellaz.com/...optic/gratings/
  • LU1AR likes this
#4 gregj888
gregj888
  • Loc: Oregon
Posted 23 May 2021 - 03:02 PM
I just had a few sheet (8.5" x 11") printed at the local Office Depot.  About $1 per sheet.  100 lpi.  They work, but are not as crisp as the WB or older (Edmunds ?) I have around.  These were printed at 2400 dpi...
Will see if I can get some slides printed locally, that looks like the way to go, especially if they can use copy or litho film.
#5 chantepierre
chantepierre
  • Loc: France
Posted 24 May 2021 - 12:36 AM
Find an imagesetter, you’ll get uninterrupted lines with clean edges.
#6 Pinbout
Pinbout
Posted 24 May 2021 - 05:46 AM
Look at it with a handheld microscope, you may change your opinion.
#7 gr5org
gr5org
    thegr5store
  • Loc: Boston
Posted 24 May 2021 - 12:09 PM
@Pinbout - the print in your image on the previous post - do you know what the printer claimed was DPI?  Was it 2400?
2400dpi is 10 microns but I don't know how they count.  Because it's color with dots colored magenta, cyan, yellow, and black then possibly each color is counted and their claim may be exaggerated by 2X (square root of 4 - this is a 2 dimensional printer).
In the article they mentioned 8k dots across the 35mm slide which is 4 microns and the 4k printers would give you 8 microns.  Again, I'm not sure if those are 4 microns per color or 4 microns per pixel.
#8 Pinbout
Pinbout
Posted 24 May 2021 - 03:49 PM
To take the same printer... I used a pdf program that spits out to the dot level.
the difference was night and day, when printing lines made in illustrator compared to the pdf program.
this one is actually usable
Edited by Pinbout, 24 May 2021 - 03:50 PM.
#9 RocketScientist
RocketScientist
  • Loc: Vermont
Posted 24 May 2021 - 04:02 PM
What PDF program did you use?
#10 Steve Dodds
Steve Dodds
  • Loc: Utah
Posted 24 May 2021 - 04:04 PM
I have this one, never tried it but it should work.
#11 Pinbout
Pinbout
Posted 24 May 2021 - 04:13 PM
You have to print it on an imagesetter
I don’t care how nice a laser says it is... it will mess it up.
so that file has to be sent out for about $75, I forget what they charge, but it ain’t $10
#12 Steve Dodds
Steve Dodds
  • Loc: Utah
Posted 24 May 2021 - 04:23 PM
I got this file from the guy at Ronchiscreens.com, he posted the file when he shut down.  He was printing it at 2400 dpi on a professional printer.
#13 Pinbout
Pinbout
Posted 24 May 2021 - 06:03 PM
I know where it came from. Try it. It won’t worker. Test it under a microscope.
#14 Steve Dodds
Steve Dodds
  • Loc: Utah
Posted 24 May 2021 - 06:22 PM
This is the file that Ronchiscreens.com was using to make their Ronchi's, and most of you have his screens.  Unless he's scamming me.
#15 Pinbout
Pinbout
Posted 24 May 2021 - 09:05 PM
Anyone can download it off his sight. Try to print it on a laser printer and inspect it with a handheld scope like what you’d use to inspect the fine grind for pits.
Edited by Pinbout, 24 May 2021 - 09:06 PM.
#16 chantepierre
chantepierre
  • Loc: France
Posted 25 May 2021 - 12:21 AM
The file is alright, but needs to be sent to an imagesetting company. The printing method is different and does not produce dots.
This was written on his website when it was still online. I made some with our graphic design studio laser printer, they were unusable. Then I found a company with film flashing machines and the result was great.
Edited by chantepierre, 25 May 2021 - 12:24 AM.
  • Pinbout likes this
#17 Pinbout
Pinbout
Posted 25 May 2021 - 11:21 AM
sorry, I spoke incorrectly earlier,  its a post script editor... can't find it.  it gets down to where to dots land...
#18 brave_ulysses
brave_ulysses
  • Loc: far outside the wire
Posted 25 May 2021 - 12:20 PM
may be useful:
http://www.laserlab.com/photoplot.php
http://fineline-imag...Nov 19 2018.pdf
