Looking for a mount similar to Skyview Pro for visual / EAA
2 replies to this topic
#1 bokemon
bokemon
  • Loc: Silicon Valley, California
Posted 18 May 2021 - 05:14 AM
Hello folks,
I have a 115mm refractor that will be used for visual, EAA, and "terrestrial photography" (if I can get the latter to work out well).
The characteristics I am looking for are:
Slip clutches for pushing around
Fine motion control
Can handle up to 15-20 lbs
RA tracking only (no goto needed)
Should be able to crank the altitude to zero so I can use it in an alt-az mode for terrestrial (not sure if the Skyview Pro can do this)
Preferably purchase-able as mount head only, since I already have the tripod from a CEM25p (I hope the base will be compatible)
For reference, I already have a CEM 25P, but it doesn't have slip clutches.  If the terrestrial photography part doesn't work out, then I guess this is ok.
I also have a Losmandy G811, but obviously that's too heavy.
#2 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 18 May 2021 - 07:13 AM
Hello folks,
Are you sure you don't want GOTO? I do a lot of EAA, and having a non-GOTO mount would make it difficult to get targets on a camera, unless you have a very large sensor camera.
#3 bokemon
bokemon
Posted 18 May 2021 - 07:25 AM
It's fine - I can plate solve
