Best C to F adapter?
14 replies to this topic
#1 Gschnettler
Gschnettler
  • Loc: Cincinnati Ohio
Posted 18 May 2021 - 09:55 AM
Hello! I am just getting into the night vision part of this hobby. I see that a lot of people recommend using camera lenses (like Nikon). I have a PVS-7 and I just ordered a C-mount adapter. I have many Nikon DSLR lenses.
What would you recommend as the best C to F adapter to connect them together?
Also, I know that you need space in the adapter to put 1.25” filters so I’m considering that as well.
Thanks in advance for your help!
#2 Joko
Joko
    Vendor - OVNI
  • Loc: FRANCE, EUROPE
Posted 18 May 2021 - 10:04 AM
Hi Gschnettler,
Not sure there is a "best" adapter, any C to F adapter should work fine.
If you need space, you can buy c-mount spacer like this : https://www.ebay.fr/...q8AAOSwRfxcGjQU
There are many sizes available and many sellers on ebay and/or Amazon.
#3 GOLGO13
GOLGO13
  • Loc: West Virginia
Posted 18 May 2021 - 10:51 AM
You need to make sure it has a feature to open the aperture all the way.
I use this one https://www.amazon.c...21352954&sr=8-3
I also sacrificed an old color filter so I could use 1.25 inch filters with it. Or just put a 2 inch filter on the front.
#4 GOLGO13
GOLGO13
Posted 18 May 2021 - 10:53 AM
camera adapter filter
unfortunately this is still a bit tall inside there and I can only use my low profile Astronomik filters inside it. But that’s ok for my situation. Someone can always keep grinding it more thin.
#5 cnoct
cnoct
  • Loc: Hawai'i
Posted 18 May 2021 - 11:56 AM
The classic factory Nikon F Mount to C Mount lens adapter, the ones that are stepped and feature soft textured blackened coating, not the black anodizing which under IR, just becomes a nice mirrored surface. These adapters tend to command higher prices but you will optimize your systems efficiency with them.
#6 tcc
tcc
Posted 18 May 2021 - 03:45 PM
This is my setup when using Nikon lens with PVS-7 :
As shown in the picture (with a 135mm/f2.8 nikon lens) :
Part#1 https://www.ebay.com/itm/402792111678
Part#2 https://agenaastro.c...-extension.html
Part#3 https://agenaastro.c...apter-v-03.html  A 1.25" filter is screwed inside this adapter in the picture
Part#4 is a dust cap to protect the lens when not in use  https://agenaastro.c...-cap-ect2f.html
I have Parts #1 & #2 attached to each nikon lens I use. Also, I have Part#3 for each filter I use and installed. This way, changing lens and/or filters is easy especially in winter with gloved hands.
This is the whole thing put together. The distance from the flange of the nikon lens to the front of the C-mount is 27mm. This distance can be increased and decreased by the length of the T spacer (Part#2). I have tried the 5mm T spacer and it can still reach the T thread inside Part#3.
It is easy to go from observing with lens to telescope by adding a 2" spacer to Part#3. The following picture shows a 1-inch 2" spacer screwed onto Part#3
  • cnoct likes this
#7 a__l
a__l
Posted 18 May 2021 - 03:52 PM
 The adapter that I bought from Aliexpress for about the price is higher.
There is a nuance. H-alfa is not recommended for lenses faster than f/2.0 in converging cone.
Edited by a__l, 18 May 2021 - 03:54 PM.
#8 cnoct
cnoct
  • Loc: Hawai'i
Posted 18 May 2021 - 11:50 PM
That is an exceptionally well thought out system.
#9 a__l
a__l
Posted 20 May 2021 - 06:40 PM
cnoct,
In your opinion, there will be a noticeable difference between these two devices when viewed from NV?
#10 Gschnettler
Gschnettler
Posted 14 July 2021 - 12:56 PM
I’m trying to recreate the setup listed above. But the ebay item #1 isn’t available anymore.
Would this one work in its place?
https://www.ebay.com...1-127632-2357-0
#11 tcc
tcc
Posted 14 July 2021 - 01:28 PM
https://www.ebay.com...1-127632-2357-0Y
Yes. This will work.
#12 a__l
a__l
Posted 14 July 2021 - 03:22 PM
Not only this.
Poor coating will crumble over time. I haven't used my SIPS for a long time. At the moment I upgraded it, but I saw a black dot on the lenses inside the device. It is difficult to remove it at home (a lot of dust). This requires a special room.
#13 Gschnettler
Gschnettler
Posted 14 July 2021 - 04:25 PM
Ok, all parts have been ordered…1, 2 3 and 4. Can’t wait to try them all out!
#14 Gschnettler
Gschnettler
Posted 21 July 2021 - 12:32 PM
I received parts 2,3 and 4. Still waiting on part #1 to attach to the Nikon lens. Parts 2 and 3 seem good…they screw into the PVS-7 and each other ok.
But, what is part #4 for? It doesn’t seem to fit anything.
#15 tcc
tcc
Posted 21 July 2021 - 01:49 PM
Part #4 is a dust cap with female T-thread. It can be screwed onto Part #1 or #2.
I leave Part#1 & 2 on the nikon lens all the time so I use Part #4 to prevent dust from getting into the nikon lens barrel when not in use. (see picture in my previous post #6 above). If you are taking the adapters off the nikon lens after use with NV, then you do not need this part.
Edited by tcc, 21 July 2021 - 01:57 PM.
