Can a PVS-14 objective be converted to an "Envis lens" ?
34 replies to this topic
#26 maxmir
maxmir
Posted 13 July 2021 - 07:21 PM
Sorry to hear your lens died
May be I just got lucky on the Carson Lens
Max
#27 a__l
a__l
Posted 13 July 2021 - 07:33 PM
I have studied this issue more closely. The problem is that under the name "Carson" there can be different objectives in terms of mechanics.
But this is only a guess. There is no exact information.
I think c-mount is a serious risk for any PVS-14 objectives.
Edited by a__l, 13 July 2021 - 07:55 PM.
#28 a__l
a__l
Posted 15 July 2021 - 05:23 AM
ArsMachina, I may not be able to get this message across in this forum to completion. Therefore, I leave the intermediate result.
TV 55/67 -> adapter M38.5x0.75 (female) 1.2"x32Tpi (male) -> PVS-14 lens with thread М28.5x0.5 -> adapter with stop plane with thread М28.5x0.5 (female) М31x0.75 (male) -> NV with М31x0.75 (female).
Edited by a__l, 15 July 2021 - 05:30 AM.
  • ArsMachina likes this
#29 maxmir
maxmir
Posted 15 July 2021 - 07:50 AM
I thought C threads were a disaster ?  I assumed that the lens body broke up.
#30 a__l
a__l
Posted 15 July 2021 - 04:56 PM
Yes it is.
I tried to make repairs. Spent a lot of time. Made one inner ring ~ 26.5 mm in diameter. Glued to "steel welding". Then I made an outer thin ring. Diameter 28.5 mm. Then I glued two parts with this ring.
But I don't have a specification for the exact dimensions between the glasses inside the objective. Outcome, failure.
The adapter(I) is needed to make a thread on the objective.
The adapter (II) is needed to do the objective test.
Edited by a__l, 15 July 2021 - 11:56 PM.
#31 a__l
a__l
Posted 30 July 2021 - 11:07 PM
The second glass came to me. Most likely Fujinon (Carson?). It clearly has a shorter distance from the rear lens to the focal plane. Those the first I put together incorrectly (after the crash).
I hope that all the fuss is not in vain and Gavster is right and the stars in this will be better than in my second Fujinon (CF-75) and afocal in my Zeiss.
Edited by a__l, 30 July 2021 - 11:09 PM.
#32 a__l
a__l
Posted 03 August 2021 - 07:41 AM
Subtotal.
Thread 28.5x0.5 mm - Ok.
Focus 1x and infinity. Does not work. Does not give NV inner restraint ring. Maybe 1 mm is missing (?) This is not critical for me, Zeiss Tevidon suits me.
Afocal TV67. Vignetting with the PVS-14 lens is clearly less than with Zeiss. What well. The focus will most likely work. The quality of the stars, time will tell. It has been cloudy for a long time. I expect good weather.
Edited by a__l, 03 August 2021 - 08:17 AM.
  • cnoct likes this
#33 a__l
a__l
Posted 04 August 2021 - 08:17 AM
Looked between the clouds. Afocal. The focus is fine. Waiting for the good sky.
#34 a__l
a__l
Posted 14 September 2021 - 10:20 PM
I would like to finish with a description of this mini-project.
In afocal with TV67 it works well. The telescope focuser makes it possible to sharpen the image with a small additional inward movement. An added bonus is the low weight of this lens.
Also, using a 31mm interface instead of c-mount is good. If I understand correctly, there is only one vignetting subject left, 2" paracorr-2.
I recommend this upgrade to the PVS-14 lens.
Additionally, I upgraded my old MoonLite focuser, as I did not like the 2" FT focuser mounting on two small screws (to which I added another).
MoonLite is a much stronger 4-screw mount to my telescope's carbon board.
https://www.cloudyni...3#entry11336018
Afocal use of NV requires a lot of console load and so far it works well on upgrade MoonLite.
Edited by a__l, 14 September 2021 - 11:11 PM.
  • cnoct and AllStarez like this
#35 cnoct
cnoct
  • Loc: Hawai'i
Posted 15 September 2021 - 06:08 AM
Most excellent, good to know it worked out in the end.
