Glitches with remote observatories
9 replies to this topic
#1 PABresler
PABresler
  • Loc: Los Osos, Ca
Posted 30 May 2021 - 02:00 PM
I have an observatory in my yard which I usually operate remotely from my house. Sometimes things happen though and I need to go out there, like a camera disconnecting in software. The only way to get it back is to plug it in again. How do you handle that with a remote observatory which really is remote?
Peter
  • archer1960 likes this
#2 archer1960
archer1960
  • Loc: Southern New England
Posted 30 May 2021 - 02:51 PM
In my case, I found that cycling the power is usually sufficient to bring things back, so I bought an IP controlled 8-poistion relay bank, which allows me to cycle the power to most of my components individually. If that fails, I can cycle the power to the entire rig and/or the computer via an IP-controlled power strip. So generally the only thing I have to go outside for is to remove the cover at the beginning of the night.
  • Raginar likes this
#3 ac4lt
ac4lt
  • Loc: Shenandoah Valley
Posted 30 May 2021 - 02:52 PM
The Pegasus Astro Ultimate Power Box v2 can cycle its USB ports effectively unplugging and re-plugging in the USB cable. Definitely helpful for remote situations.
#4 TOMDEY
TOMDEY
  • Loc: Springwater, NY
Posted 30 May 2021 - 02:58 PM
You yet again call your brother who owns the country estate. He yet again agrees to climb out of bed and take a look... but this time adds that he's decided to plant corn right on that exact spot next week.    Tom
  • John Miele, Astrola72 and t-ara-fan like this
#5 PABresler
PABresler
  • Loc: Los Osos, Ca
Posted 30 May 2021 - 03:41 PM
That sounds like a good solution, but not really necessary for my situation since I can easily go out there to re-plug.
It sounds like a nice observatory you have there. Why are you selling it? I am not too familiar with the real estate market at that location. Say you value the observatory and scope at $50,000. That leaves $440,000 for the house. That sounds pricey for a pre-fab house in a remote location?
Peter
#6 Alex McConahay
Alex McConahay
  • Loc: Moreno Valley, CA
Posted 30 May 2021 - 10:07 PM
Sometimes it gets fixed by cycling the power......SOmetimes I have to pull the USB cable (my camera and filter wheel in particular), wait five seconds, and plug it back in. Is there a device similar to the power controller that will cycle a USB port?
Alex
#7 SimonIRE
SimonIRE
  • Loc: South East England
Posted 31 May 2021 - 02:19 AM
Alex
Pegasus Ultimate Power Box will do this and is really good.
I also have one of these (link below), which is quite simply the best USB hub I have every used. I have 2 full frame CMOS cameras, a 1600mm and several guide cameras and this hub handles them all, at the same time, easily. You can cycle all the ports individually and you can also connect it to 2 computers and switch between them. This is a really really useful function for mission critical kit like your observatory roof. Expensive, but well worth it. Also programmable.
https://acroname.com...e/s79-usbhub-3p
Edited by SimonIRE, 31 May 2021 - 02:21 AM.
#8 Phil Sherman
Phil Sherman
  • Loc: Cleveland, Ohio
Posted 31 May 2021 - 09:08 AM
I've also use software that supports resetting a USB port at the computer. If this doesn't work, removing the driver and power recycling everything should also fix the problem but this is the equivalent of using a sledgehammer to kill a fly. Most of the time, power cycling the computer will do the trick.
#9 Alex McConahay
Alex McConahay
Posted 31 May 2021 - 09:44 AM
What is the software?
I would imagine it should be in the operating system, right?
Alex
#10 Phil Sherman
Phil Sherman
Posted 01 June 2021 - 11:48 AM
Alex
Devcon, a downloadable Microsoft utility will do it. The program is difficult to use.
