I know this thread is old, but I wanted to buy the DX 6 SCT, as it was on a sale and was hardly able to find any review or opinion on that.
I previously owned a DX 102AZ or formerly known Omni 102 with its mount and DX 6 SCT comes with the exact same mount. It is quite mediocre, but most of you were worried about its weight. I don't know how the 5" SCT performs, but the 6" SCT performs well. Of course the 102 refractor was a little bit lighter and overall was easier to use on the mount, but I think the DX 6 is still okay.
Would buy a new mount in the future, but this old one does its job. The only problem is that it is sensitive to any movement (you use the slow motion handles, there is a slight wind etc.), so not the most accurate, but unless you use it for photography, you can see everything well on it.
The 6" is not that big, so still good for travel and going outside of town, so relatiely easy to handle and if I'm not wrong I can use 2" eyepieces with it, but that I have to double-check. It came with a 10mm Plössl and 40mm wide angle eyepiece, both are good quality, not the ones you would change (like the 10mm and 25mm EPs which came with the Omni 102).
Unfortuntely, the German weather is not too generous in summer either, so I rarely find the time to use it, but I can fully recommend it to people, who has to travel to see the night sky. I live in a Bortel 6 area, so still okay to use the telescope, but better to go outside of town (obviously:) ). It does a decent job with nebulas and also good for planets. It is not extraordinary in anything, but overall performs well. A good compromise.
