hi all
after struggling with bad star trailing on my new setup (see here); I still need to dump at least 60-70% of my subs due to high eccentricity (>0.6).
After yesterdays session I noticed that one sub showed a very wobbly satellite trail (see attachment). This was a 120sec sub taken on LUM filter
using a ASI 294MM at -15°C. Conditions yesterday were very good, no wind, clear skies, above average seeing. Seems to go mainly in RA direction.
Setup details: TS Optics 130mm Photoline refractor at native 910mm FL (1.0x flattener) on a CGEMii mount. Guiding was very good yesterday
night using a cOAG / 174mm mini; PHD2 showed 0.5" error on average (one of the better sessions so far). The mount is on the native tripod that
comes with the mount, standing on a thick concrete floor).
Questions/thoughts:
- Anyone has seen this before? This looks like a periodic 'wobble' in my imaging train.
- It seems to be irregular (the other satellite trail is not that affected, also the wobbling is not consistent in the entire trail).
- Could this be to the weight/length of the setup? Although the CGEMii is rated up to 18kg (is this without counter weights?), the refractor
is already at 10-11kg without imaging train (so in total I would estimate around 12 kg or so). - Ever since I bought my mount, you can slightly move it (when its not powered) around the RA axis (just a slight movement), is this normal?
Is this the backlash in the RA axis? - Would it be good to hypertune the mount for this? I don't see a lot of experience around hypertuning the CGEMii (but you can buy the kit).
Edited by Invator, 02 June 2021 - 01:44 AM.
