Issues with Firecapture and ZWO ASI 174MM Camera
Astrophotography Celestron Equipment Imaging Planet SCT
7 replies to this topic
#1 sandconp
sandconp
  • Loc: Minnesota USA
Posted 09 June 2021 - 01:01 PM
I am trying my new ZWO 174MM (monochrome) Planetary camera for the first time using Firecapture and it really seems to respond slowly.  The data seems to be received in 'chunks'  (stops a bit) and then continues on.  I did not have this problem with my ZWO 178 OSC Camera.  The GUI also seems to run slow when I use this camera.  I don't know if I need to 'tune' something with Firecapture to make it not hang.  I am getting a decent FPS count which seems strange for as long as it stalls.
I do not have this problem when using Sharpcap Pro with the same camera.
I was also wondering if there is a Firecapture Forum so that the developer might see this problem and respond?
#2 spereira
spereira
  • Loc: Bedford, NH
Posted 09 June 2021 - 02:03 PM
As far as a Firecapture forum, I found this with Google:
https://groups.io/g/firecapture
smp
#3 Tulloch
Tulloch
  • Loc: Melbourne, Australia
Posted 09 June 2021 - 04:03 PM
Do you get a warning that says "Capture failed" when the transfer stops? If so, then reducing the "USB Traffic" setting to something around 50 - 70 might help. A lower value reduces the maximum transfer rate, but makes the transfer more stable (I think).
#4 sandconp
sandconp
Posted 09 June 2021 - 04:07 PM
I believe that is the case.  Where is that setting?
#5 Tulloch
Tulloch
Posted 09 June 2021 - 04:23 PM
On the left hand side, choose the little gear wheel icon in the "Control" tab, you should see this window.
While you are there, select "high speed mode" also.
#6 sandconp
sandconp
Posted 15 June 2021 - 07:26 AM
I did find the high speed mode on this version but I then downloaded the most recent Beta Version and I cannot find the high speed option under the gear tab.
I wonder if they took it out of the Beta Version?
#7 Tulloch
Tulloch
Posted 15 June 2021 - 04:09 PM
It's still there in ver 2.7, it's now under the "more" button in the Control window.
High speed mode is an essential tool in planetary imaging.
#8 jesco_t
jesco_t
  • Loc: Hamburg, Germany
Posted 16 June 2021 - 03:40 AM
You can try and enable the (experimental) RAM buffer in Settings/General. This helped me to even out disk speed variations and get a constant capture framerate.
Jesco
Also tagged with one or more of these keywords: Astrophotography, Celestron, Equipment, Imaging, Planet, SCT
