Absolute magnitude of a light bulb
10 replies to this topic
#1 EricSi
EricSi
  • Loc: Seattle, WA
Posted 11 June 2021 - 12:56 AM
For my fellow nerds who might find this amusing:
The output of the sun is 3.82 x 10^26 Watts, so 3.82 x 10^24 times as much as a 100 Watt light bulb.
Magnitudes are based on the fifth root of 100, or (10^2)^.2 = 10^0.4.
Therefore for a brightness ratio of r, the difference in magnitudes m is given by 10^(0.4 x m) = r, or m = 2.5 log r.
Thus, in this case m = 2.5 x (24 + log 3.82) = 2.5 x (24.58) = 61.46.
Since the absolute magnitude of the sun is 4.83, the magnitude of a 100 Watt light bulb at a distance of 10 parsecs is 61.46 + 4.83 = 66.29.
Only 35 magnitudes too faint to be seen by the Hubble!
  • Astrojensen, ShaulaB, chrysalis and 1 other like this
#2 Dynan
Dynan
  • Loc: NOLA
Posted 11 June 2021 - 01:11 AM
You, Eric, are amazingly intelligent...and certainly have too much time on your hands. lol.gif
  • EricSi likes this
#3 Sleep Deprived
Sleep Deprived
  • Loc: Seattle Area
Posted 11 June 2021 - 01:25 AM
Yeah, but how many angels can fit on the head of a pin?
#4 MillHey
MillHey
Posted 11 June 2021 - 03:47 AM
Hi Eric,  so how close would the Hubble have to get to be able to see it?
#5 chrysalis
chrysalis
  • Loc: North Central NC
Posted 11 June 2021 - 03:55 AM
An interesting further exercise would be this:
Calculate the light bulb wattage equivalent to that of sunlight falling on the earth's surface. Then extend that to the surface of Pluto - in order to get a good feel of what the lighting power of the Sun would be from 2.48 billion miles.
This would provide a realistic visual impression of the Sun not at magnitude -26.9 but at (whatever the apparent magnitude of the Sun is as seen from Pluto).
And for more fun - determine the ratio between that and the appearance of the ground on  Earth during a Full Moon at it's highest.
#6 Tony Flanders
Tony Flanders
  • Loc: Cambridge, MA, USA
Posted 11 June 2021 - 06:15 AM
Which means that at 1 parsec the bulb would appear 100 times brighter: mag 61.29, and 30 magnitudes (a factor of 100^(30/5) = 10^-12) too faint for Hubble.
From which we conclude that the maximum distance at which the Hubble Space Telescope can see a 100-watt light bulb is one millionth of a parsec, which works out to 0.2 a.u., or 30,000,000 km.
So when Venus is closest to Earth, the Hubble would be able to see a 200-watt light bulb on Venus, but not a 100-watt light bulb. Ignoring the fact that Hubble would likely be permanently damaged by pointing so close to the Sun.
  • ShaulaB and EricSi like this
#7 EricSi
EricSi
  • Loc: Seattle, WA
Posted 11 June 2021 - 01:27 PM
Pluto's orbit is at an average distance of about 40 AU, so the sun would be 1,600 times fainter than it is here (2.5 log 1600 = 8.01 magnitudes, making it -18.9). That's brighter than I would have expected.
The full moon is about 400,000 times fainter than the sun is here (magnitude -12.7).
So even from Pluto you would have a pretty bright but tiny (roughly 40" or 45") source of light.
  • chrysalis likes this
#8 chrysalis
chrysalis
Posted 11 June 2021 - 01:36 PM
So can you equate the luminance of the Sun at -18.9 with an approximate earthly lighting condition? 1/1600th of the sun's light shed onto the earth's surface would approximate what: a cloudy day? A cloudy day at sunset or afterward? Dusk? Wonder if this correlation is possible. I'm sure it could be done (somehow) in terms of lumens/square meter, but that just provides a number, not a real-world example so we in the audience can perceive it and experience an "Aha!" moment...
#9 Mister T
Mister T
  • Loc: Upstate NY
Posted 11 June 2021 - 04:58 PM
That is why you should use LEDs!
#10 KBHornblower
KBHornblower
  • Loc: Falls Church, VA (Washington DC suburb)
Posted 11 June 2021 - 08:53 PM
The light level from the Sun at Pluto is similar to that of ordinary indoor household lighting at night.
#11 spacemunkee
spacemunkee
  • Loc: Cincinnati, Ohio
Posted 13 June 2021 - 05:17 PM
Now if we can just find those light bulbs on another planet... Those horrible 7k LED's should stand out pretty well!
https://www.scientif...-other-planets/
