Spaceplates
17 replies to this topic
#1 boothg599
boothg599
Posted 11 June 2021 - 02:59 AM
What do y'all think about a project using these things? https://www.nature.c...467-021-23358-8
#2 luxo II
luxo II
  • Loc: Sydney, Australia
Posted 11 June 2021 - 03:56 AM
That is so packed with buzzwords it was probably writtten by a buzzprose generator.
Anyway that definition of “spaceplate” is satisfied by solid glass - a solid optic could be 30% shorter than one full of air. Only snag is the weight.
Think I’ll file the at one in the round file, along with cold fusion and the mysterious fictitious magical “quantum telescope”
  • AstroFrankMontana likes this
#3 Gleb1964
Gleb1964
  • Loc: Sweden
Posted 11 June 2021 - 06:00 AM
Anyway that definition of “spaceplate” is satisfied by solid glass - a solid optic could be 30% shorter than one full of air.s magical “quantum telescope”
No, it is opposite to that - solid glass instead of air space would slow beam convergence and take 50% more space.
  • PrestonE, jtsenghas, BGRE and 1 other like this
#4 MitchAlsup
MitchAlsup
Posted 11 June 2021 - 03:51 PM
What kind of Eyepieces will we need to use at F/0.5 primaries ?
Edited by MitchAlsup, 11 June 2021 - 03:51 PM.
#5 jimhoward999
jimhoward999
  • Loc: Brentwood, Tennessee
Posted 11 June 2021 - 09:21 PM
If you put a plate of glass in an optical train it stretches the path by t(n-1)/n where t is the thickness of the plate.  To get compression of the path with a plate you need a negative index of refraction.
Negative index materials have been theorized using "meta-materials"  and demonstrated in the microwave region.  But I don't think negative index meta-materials have ever been created in the optical domain.
The authors of the article present some ideas on "spaceplate" materials they think might work.  I think these are just hypothetical ways to get at an optical meta-material with a negative index....they must be because that is the only way you get compression with a zero-power plate.  I am certainly not smart enough to analyze the presented concepts, which were difficult to follow.  But they seemed pretty fishy.
#6 TOMDEY
TOMDEY
  • Loc: Springwater, NY
Posted 12 June 2021 - 09:18 AM
It's mumbo-jumbo. Would take a nondispersive index of refraction of a thousand to even begin to get something that has a prayer of slightly working. Complete baloney.    Tom
#7 Gleb1964
Gleb1964
  • Loc: Sweden
Posted 12 June 2021 - 09:27 AM
Yes, that is correct formula.
So, to shrink the space you would need refraction index between 0 and 1. Why are you talking negative index? See in article used "a negative uniaxial birefringent medium", not a negative.
#8 MKV
MKV
  • Loc: Southeast, USA
Posted 12 June 2021 - 11:05 AM
Lol, personally, I'm waiting for deferents and epicycles to enter the stage...it worked the last time they were introduced.  :o)
How can a refractive index of a "medium" be less then unity, Gleb? Vacuum refractive index is 1. What's "medium" would it take to have one?
But, today, many things are "possible" and "real" if  you can just imagine it. :o)
According to researchgate,
https://www.research...this-phenomenon
refractive index can not only have a value of less than 1 but it can also be negative! It's sort of like the geometric raytrace result of a paraboloidal mirror on-axis -- the image is a dimensionless dot. Sure. It may even depend on what day of the week it is. :o)
#9 Gleb1964
Gleb1964
  • Loc: Sweden
Posted 12 June 2021 - 12:09 PM
Mladen
Refraction index is related to phase velocity which can by any. If refracting index less then 1, phase velocity is above speed of light. That what is happened within absorption bands, for example.
#10 jimhoward999
jimhoward999
Posted 12 June 2021 - 12:58 PM
yes you are right....brain fart on my part.  A negative index meta-material would actually increase the space even more than a plate of regular glass.
#11 jimhoward999
jimhoward999
Posted 12 June 2021 - 01:49 PM
Here is a spaceplate configuration that does work...sort of
You put a beamsplitter coating on both sides of a plate parallel plate and let the light bounce back and forth.  Of course the throughput with 4 bounces is only 1.5% and the remaining 98% of the light lives in horrible ghost images, but it still probably works as well as the hypothetical electro-optical devices in the paper.
You could also tilt the surfaces at 45° to regain the throughput
oh look I've invented the Porro prism.
The point is there are conventional ways to shorten an optical system if you are willing to add components.
#12 MKV
MKV
Posted 12 June 2021 - 06:37 PM
I guess it all depends how how one defines it mathematically. When I was in school, refrective index = n/n'. All my optical programs still treat it that way.
#13 luxo II
luxo II
Posted 13 June 2021 - 12:03 AM
And there are these funny things called mirrors. Notably concave and convex ones. I have a scope with a 3m focal length packed into an 80cm OTA.
that qualifies, according to the definition.
Edited by luxo II, 13 June 2021 - 12:05 AM.
#14 freestar8n
freestar8n
    Vendor - MetaGuide
  • Loc: Melbourne, Australia
Posted 13 June 2021 - 02:54 AM
For people interested in related topics, here is a nice summary of the long history of work in metamaterials:
https://engineering....2007/Part-3.pdf
And here is the upcoming program on metamaterials for the SPIE conference on optics and photonics:
https://spie.org/OPN...ces-metasystems
To learn more about the feasibility of refractive index < 1 you can read up on the Drude model of metals, well over 100 years old - keeping mind that "n" is a complex number.
Frank
#15 freestar8n
freestar8n
    Vendor - MetaGuide
Posted 13 June 2021 - 02:59 AM
The OP has made their first posting with this topic - so - welcome to CN.
What is your opinion of the article?
Frank
#16 Gleb1964
Gleb1964
  • Loc: Sweden
Posted 13 June 2021 - 07:38 AM
It's mumbo-jumbo.
Tom.
I have a similar filling until I can see real working examples. But I am not an expert in the area to immediately dismiss it. I think, there are special application where physics can be formally described in a such math terms.
Mladen,
refractive index is a relation between phase speed in vacuum and in media. Phase speed above speed of light is reality. The only group speed is limited to the speed of light, that is the speed of energy (information) propagation.
Ray tracing optical software is based on phase calculation. Using of negative refraction index for mirrors in software should not be confused with media negative index, meaning phase propagation in the opposite direction to the group speed.
Here is illustration of phase speed faster than group speed: https://www.youtube....h?v=tlM9vq-bepA
#17 MKV
MKV
Posted 13 June 2021 - 10:10 AM
Mladen,
Gleb,
Yes, that's correct of course. Some software (ATMOS, etc.) use the convention of negative refractive index values only to denote phase propagation in the opposite direction (reflection), not phase propagation higher than the speed of light (with no information propagation). Only refractive index values >1 carry information; the negative sign, if allowed, indicates only relative direction of wavefront propagation.
Some software allow "negative" refractive index value of -1 only for reversal of phase propagation direction (reflection). Others prohibit negative refraction index values altogether, and  force you to enter or choose a verbal designation such as "reflector" so as to never even accidentally enter a negative refractive index.
IMO, delving into ref. index values <1 or even <0  has no practical application in amateur telescope making, not even as a mental exercise.
Mladen
PS edit: typos
Edited by MKV, 14 June 2021 - 03:06 AM.
  • Gleb1964 likes this
#18 horizon
horizon
Posted 14 June 2021 - 02:16 PM
There is a company wanting to commercialise meta lenses for consumer (smartphone camera) and automotive applications:
https://www.metalenz.com/
Most (all?) meta materials rely on structures that are smaller than or are on the order of the wavelength of the light passing through it. It's a matter of manufacturing these structures cheaply and consistently in order the move from the lab to consumer applications.
I your thinking about telescopes then think of a lens being manufactured like microchips on a silicon wafers.
Personally I'm very excited about this technology and hope to see more applications in the next decades.
Greetings,
Edited by horizon, 14 June 2021 - 02:19 PM.
  • LU1AR likes this
