SKYFI and Celestron CG5 Advanced how?
5 replies to this topic
#1 patrizioitalian
patrizioitalian
  • Loc: ITALY
Posted 11 June 2021 - 06:10 AM
I have a SKYFI device version 2 and a CG5 Advanced mount.
I would like to use it with this mount and connect it to the remote control.
Can I do this?
But I discovered that RJ11 pins on the remote Celestron Controller are 4 and pins that comes out from the RJ connector of the SKYFI are 6 so how I COULD MAKE THE RIGHT CABLE?
Is there anyone who knows which pin to use to make a 6-pin 4-pin cable to be included in the CG5 Advanced?
thanks
Edited by patrizioitalian, 11 June 2021 - 06:52 AM.
#2 wrvond
wrvond
  • Loc: West Virginia
Posted 11 June 2021 - 07:26 AM
Here you go:
https://skysafariast...yfi/serial.html
#3 patrizioitalian
patrizioitalian
  • Loc: ITALY
Posted 13 June 2021 - 02:40 AM
Understand, thanks but in my case that I don't have the serial adapater, maybe I could do wiht RJ connectors, it is useless to put a DB9 in the middle (or rather two). I think the two pieces of cable can be connected together by putting an RJ 4 pin aside and RJ11 (6 pin).
there is no electronics in between but only connections.
Something like this could be work, without using any DB9 Serial connector
Pat
Edited by patrizioitalian, 13 June 2021 - 02:45 AM.
#4 RTLR 12
RTLR 12
  • Loc: The Great Pacific NorthWest
Posted 13 June 2021 - 03:46 AM
Pat,
You need the serial cable adapter #93920 from Celestron.
You can find it here:
https://agenaastro.c...unts-93920.html
Stan
#5 patrizioitalian
patrizioitalian
  • Loc: ITALY
Posted 13 June 2021 - 04:11 AM
Pat,
Stan
I have one homemade that I used in the past with MEADE Autostar #497, is it the same I suppose
this one:
Edited by patrizioitalian, 13 June 2021 - 04:13 AM.
#6 RTLR 12
RTLR 12
Posted 13 June 2021 - 08:44 AM
I don’t know for sure, but I think that the Meade and Celestron serial cables are wired differently.
Stan
