qhy8L IR window scratched. any way to change it?
4 replies to this topic
#1 Sniuk
Sniuk
  • Loc: Barcelona, Catalonia
Posted 11 June 2021 - 08:02 AM
the IR window of my qhy8l  has scratches, one quite big... as you can see in the picture below. Also attached a flat frame
the scratch "shadow" is pretty big..
I've contacted qhy and they asked around 100€ (including shipping ) for sending the window (not just the glass...but the whole thing)
So I am looking for alternatives and wondering if someone has replaced it succesfully with a filter of other brand (and perhaps better...
at least in the sense of durability)
I usually image from home (bortle 7) and use Optolong L-pro, but with good weather coming, wanted to go to a darker site some times and
thus will remove the L-pro. Question is.. how much will affect to the overall image? Right now, even though the L-pro I assume it also cuts
the IR , the effect I see is on bright stars specially, even using flats. (like the example below, a crop from running man nebula )
Thanks in advance,
clear skies!
#2 dghent
dghent
Posted 11 June 2021 - 11:55 AM
I'm not sure about a window that has better durability but what is going on that is creating such large scratches in the first place?
  • Sniuk likes this
#3 Sniuk
Sniuk
Posted 11 June 2021 - 12:03 PM
Actually, no idea...  I had the small circular ones already (bought this second hand a while back )  but around...a month ago or so ? I unscrewed the camera from the T2 extender, and then I've put it back... I don't recall bumping into it, but it would be the only explanation. Even though the window-glass itself is "deep"into the nose piece ...It is weird it got scratch when I didn't even "feel" it.. I saw later in the subs, before doing the flats..
but besides the durability,  did you change any glass from a QHY camera? or another one for that matter. I m not sure if it is glued or what.
Edited by Sniuk, 11 June 2021 - 12:04 PM.
#4 Tayson82
Tayson82
  • Loc: Poland / Wolomin
Posted 16 June 2021 - 06:58 AM
You can remove blocken glass ang put someware Baader 2" ir/uv blocking filter.
The question is what about the humidity during cooling camera when You remove glass.....
Edited by Tayson82, 16 June 2021 - 06:59 AM.
  • Sniuk likes this
#5 Sniuk
Sniuk
Posted 16 June 2021 - 08:56 AM
 Thanks for your answer
Qhy mentioned to break the glass and glue another one
Fom his email, apparently glass is
IR680+AR40*3.0.
The diameter is 40mm.
So will get a 2" one take off the ring and try to glue. I guess.
Although 2" is bigger than 40mm but since it goes glued insise, guess could be fine.
This way the humidity problem you mentioned should occur if I finally do it successfully, will post pics here
