Awful DEC backlash IOptron CEM25p
6 replies to this topic
#1 rocketjake5
rocketjake5
Posted 13 June 2021 - 03:07 PM
Hello,
My ioptron mount has been giving me such pain. It guides great in RA, <.50 RMS. But the DEC axis is plagued with terrible backlash causing my stars to elongate. The guide graph in PHD2 has a saw tooth pattern just like some other users have reported. I have yet to identify the source of backlash. The mount is now sitting on my work bench in pieces as I am attempting to solve this for good. Does anyone have any experience with the Ioptron CEM25p and its notorious DEC backlash?
I have adjusted the tension on the belt drive so that it flexes no more that 3mm as recommended by iOptron. Still, DEC guides badly. The worm drive is rock solid in its housing and the pulley grub screw is tight. There is no play in the DEC when I rock the saddle by hand which tells me that the gears are meshed properly.
I am not sure what more information to include. Please help my poor mount :)
#2 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 13 June 2021 - 03:15 PM
The first thing that I would advise doing is to put an eyepiece in and using the hand controller see for sure that it's the mount and nothing else. Elongated stars can come from many different issues.  U
sing PHD's backlash calculator conflates all of them into one often useful number.
Your mount is belt driven and if the mesh is properly adjusted backlash is going to be negligible. Try a manual star test before doing anything else.
It would be useful to post a picture of the system and a PHD guiding log. Maybe there's something that you are overlooking.
Rgrds-Ross
#3 bips3453
bips3453
  • Loc: MN
Posted 13 June 2021 - 05:00 PM
Even if Dec backlash is there, it shouldn't matter with a good PA...
Edit: This may not be true in all cases, Thanks Michael!
Edited by bips3453, 14 June 2021 - 06:48 AM.
#4 rocketjake5
rocketjake5
Posted 13 June 2021 - 05:20 PM
Rgrds-Ross
I will post a snap of my guide graph if its clear soon. Maybe my settings in PHD are way off, but I know for sure that the DEC has backlash because I have performed the cross test is PHD. I just put the mount back together--will see if I did something right.
#5 jesco_t
jesco_t
  • Loc: Hamburg, Germany
Posted 14 June 2021 - 03:05 AM
Unidirectional guiding might help you if backlash is really the issue. If you guide only north or south (depending) this will avoid direction reversal and will hide the backlash. Your mount might still guide okay this way.
Jesco
#6 michael8554
michael8554
  • Loc: Wiltshire UK
Posted 14 June 2021 - 05:49 AM
Good PA means Dec should only require infrequent corrections,
But if Dec balance is "perfect", the slightest wind or cable tug will send Dec wobbling between the extremes of the Backlash.
  • bips3453 likes this
#7 rocketjake5
rocketjake5
Posted 14 June 2021 - 06:36 PM
Had a clear night. The DEC backlash is a lot better :)
My DEC was still oscillating while guiding, so I changed some settings in PHD. Doing that really improved my guiding and minimized the saw tooth pattern.
