Mirages during recent solar ecplise?
12 replies to this topic
#1 flincken
flincken
Posted 14 June 2021 - 04:53 AM
Hi, I am pretty new to solar photography so please excuse a newbie question. During the recent eclipse I was shooting with my Solarmax 90mm and ZWO174 and it is usually very straight forward to find and focus on the sun. During the ecplise I had a lot of issues with solar flares and weird "mirages" when trying to find the sun. When I found what I thought was the sun (including the shadow of the moon) I was not able to find focus (on the 90mm I usually have to extend it fully + extend the camera a bit more to find focus, now to find the closest i could to focus I had to retract the full tube quite a lot) + it was much dimmer than usual and I had to push the gain to over 300 (usually have it at 0-30 for 10ms exposures)
After giving up on finding focus I started to move the telescope around a lot and found the real sun, and all was back to normal
Any ideas of what was going on?
#2 rigel123
rigel123
  • Loc: SW Ohio
Posted 14 June 2021 - 04:58 AM
Is this a double stacked unit?  If so, it sounds like you were trying to focus on the “ghost” image that is in DS setups.  If not, I have no idea what you might have seen.
  • hopskipson and Robinodavo like this
#3 hopskipson
hopskipson
  • Loc: Queens, New Yawk, Light pollution Headquarters!
Posted 14 June 2021 - 06:08 AM
That was my thinking as well.  It's happened to all of us I'm sure.
  • rigel123 and Robinodavo like this
#4 flincken
flincken
Posted 14 June 2021 - 08:01 AM
Hi yes it is, never heard of the ghost image, (havent seen it before the eclipse =), but that should explain it, thanks!
#5 rigel123
rigel123
  • Loc: SW Ohio
Posted 14 June 2021 - 08:45 AM
Typically the ghost image will show up near or overlapping the real image until you tune your second etalon to just move it off the real image
#6 flincken
flincken
Posted 14 June 2021 - 11:19 AM
what confused me was that the ghost image was in a "fixed" position on the sky (did not move when I moved the scope) and that it was far enough from the actual sun so that you didnt see them both at the same time. I tried to generate the same phenomena again by tuning the etalons without success yesterday
#7 rigel123
rigel123
  • Loc: SW Ohio
Posted 14 June 2021 - 11:50 AM
So if you moved your scope the image stayed in the field of view at the same position?
#8 flincken
flincken
Posted 14 June 2021 - 12:08 PM
not sure if I get your meaning, what I was trying to say was that the ghost image felt like it had a "fixed" position on the sky in the same way the sun has, i.e needed to track the ghost and i could frame it in the same way I can the sun
#9 flincken
flincken
Posted 14 June 2021 - 12:14 PM
here is a pic of the ghost, you can also see some other artifacts on the sides (not sure how I insert a pic so I add a dropbox link)
https://www.dropbox....g?role=personal
#10 rigel123
rigel123
  • Loc: SW Ohio
Posted 14 June 2021 - 12:34 PM
OK, interesting.  The Dropbox link you posted takes me to my Dropbox for some reason and says the file doesn't exist.  If you can make your image a jpg and under 500kb you can just use the Full Editor and choose the file to insert in your post.
#11 flincken
flincken
Posted 14 June 2021 - 03:13 PM
trying again =)
#12 vincentv
vincentv
  • Loc: Costa Rica
Posted 14 June 2021 - 04:42 PM
Next time you are in doubt use the tilt tuner:
-image moves -> it's a reflection
  • hopskipson likes this
#13 rigel123
rigel123
  • Loc: SW Ohio
Posted 14 June 2021 - 08:56 PM
That looks like the ghost image in a double stack scope, the actual image is out of the FOV.
