Leveling Screws for DYI dob buggy
5 replies to this topic
#1 Shane1200
Shane1200
  • Loc: North Florida
Posted 16 June 2021 - 10:25 PM
I just finished building my dob buggy except for the leveling screws. Does anyone know of where I can purchase them or any suggestions on how to make them?
Thanks. I can post a picture if anyone wants to see it.
#2 Couder
Couder
  • Loc: Mansfield, Missouri in the Ozarks
Posted 16 June 2021 - 10:31 PM
We used chair leveling feet - they come with the piece to put into the wood, TeflonĀ® pads, and long adjusting screws.
#3 lphilpot
lphilpot
  • Loc: Central Lousiana, USA
Posted 17 June 2021 - 08:32 AM
Good place to start looking: https://www.mcmaster.../leveling-feet/
#4 TelescopeGreg
TelescopeGreg
  • Loc: Auburn, California, USA
Posted 17 June 2021 - 05:49 PM
1/2" Carriage bolts and a pair of nuts.
In use, I lift the trolley to the upper nut, then finger tighten the lower nut upward.  I don't generally need to use a wrench on the nuts, especially if the length of the bolt is short.  Using a block of wood (usually a bit longer than pictured here) under the bolt helps greatly in this regard.
#5 Shane1200
Shane1200
Posted 17 June 2021 - 10:18 PM
I think I will try your carriage bolt suggestion.   I was thinking of using a 1/4 threaded rod and placing a board under it, but the  problem is the rods come only in 3 feet lengths at the local hardware store, which would require a lot of hacksaw work.
#6 lphilpot
lphilpot
Posted 17 June 2021 - 10:49 PM
I recommend using something heavier than 1/4x20 bolts. The suggestion for 1/2" is good. Quarter inch bolts will flex, imparting shake to the scope. Also, use a countersink or Forstner bit smaller than the carriage bolt head to create a shallow hole in the wooden block into which the bolt head will nest.
