Edge hd external focuser
Beginner Celestron Catadioptric Accessories
3 replies to this topic
#1 TintiNite
TintiNite
Posted 18 June 2021 - 10:46 PM
Real newbie here!
If focusing via primary mirror movement is not ideal, can you lock the primary permanently and use an external focuser?
#2 james7ca
james7ca
  • Loc: San Diego, CA
Posted 19 June 2021 - 02:59 AM
Yes, I have that exact setup on my 9.25" EdgeHD. I still use the built-in focuser for rough focus, but then I lock the mirrors and use a 2" Feathertouch Crayford focuser for final focus. That said, the mirror locks on the EdgeHD won't really keep the primary mirror from moving, they just make it less likely to move. I also unlock the mirror at the end of the session.
Edited by james7ca, 19 June 2021 - 03:04 AM.
#3 rmollise
Posted 19 June 2021 - 01:28 PM
It really shouldn't be an issue. In most modern scopes, focus shift--if that is your issue--is less than 45". Also, the Edge has different requirements for spacing on the rear cell compared to the standard scopes. Be sure to take that into account.
  • Linwood likes this
#4 Linwood
Linwood
  • Loc: Ft Myers, Florida, USA
Posted 19 June 2021 - 07:33 PM
And especially if you are new to using it, just wait until you settle into a routine, i.e. what kind of imaging train you plan, since backfocus and potentially rotation (auto or manual) become a thing, and the train (mono or color, filter wheel, etc.) can make a lot of difference.
Also, as @rmollise says, make sure you are fixing a problem you have, not just one you read about.
Also tagged with one or more of these keywords: Beginner, Celestron, Catadioptric, Accessories
