Using Computar 75mm F/1.4 with front mounted 2" filters
10 replies to this topic
#1 John Vogt
John Vogt
Posted 19 June 2021 - 02:14 PM
Has anyone tried using the 75mm Computar w/ front mounted 2" filters?
I realize there will be vignetting but not sure how much. I know a few others in the group have
resorted to using drop in 1.25" filters in the rear of the lens but figured I would give this a try.
John
#2 AllStarez
AllStarez
Posted 20 June 2021 - 08:27 AM
I have that same lens but usually use 1.25 filters, but i would be interested too in using a 2’’ front mounted smile.gif
#3 longbond
longbond
  • Loc: Chicago
Posted 20 June 2021 - 10:32 AM
Hi John, you should be okay with a front-mount 2" filter. I have a pair of Pentax 75mm f/1.4 C-mount lenses. This is the same as a Cosmicar 75m f/1.4. It has a clear aperture of 53mm and uses 58mm x 0.75mm filters. If your Computar has the same front filter threading, you could use a 48-58mm step-down ring to front-mount your 2" filter. 2" filters usually have a clear aperture around 44mm, so you're not giving up too much to get the benefits of front-mounting.
  • GeezerGazer likes this
#4 AllStarez
AllStarez
Posted 20 June 2021 - 10:50 AM
Thanks longbond, 48-58mm step-down ring should fits great. I have a 48-56mm and its a bit too short
  • longbond likes this
#5 John Vogt
John Vogt
Posted 20 June 2021 - 11:48 AM
Thanks longbond!
I have a 58 - 48mm stepdown coming on Wednesday. I also just received a 2" Antlia 3nm Ha and
a Baader 2" 685nm long pass, looking forward to the views!
#6 longbond
longbond
  • Loc: Chicago
Posted 20 June 2021 - 01:42 PM
Your welcome AllStarez. It helps that we both have the same lens! Now you'll be able to do front-mount and rear-mount comparisons with 2" filters.
#7 longbond
longbond
  • Loc: Chicago
Posted 20 June 2021 - 01:54 PM
John, you planned out that Antlia 3.0nm filter purchase pretty well! I have that same 2" filter and I've measured it to be good to about 14½ degrees TFOV. Beyond that, band shift shows-up and the outer field disappears. At 75mm (approx. 13 degree TFOV), you're just under the wire and good to go!
#8 AllStarez
AllStarez
Posted 20 June 2021 - 02:17 PM
Yes thats’ exactly the idea :)
i just have one 2’ filter for now (7nm) that i’d like to compare to its 1,25 brother
#9 John Vogt
John Vogt
Posted 20 June 2021 - 03:47 PM
Thanks for the additional info longbond!
I debated spending that kind of money but am now glad I did based on your comments.waytogo.gif
#10 longbond
longbond
  • Loc: Chicago
Posted 20 June 2021 - 04:17 PM
John, I should clarify a little on the 2" 3.0nm Antlia. It will work fine front-mounted on your 75mm f/1.4, but this filter can be a harsh mistress. Some have reported band shift difficulties when rear-mounted (internally). I also have this 3.0nm filter in 1.25" and it's good to 17½ degrees front-mounted (versus 14½ degrees for the 2"). I don't know why...maybe a slight difference in bandwidth or center wavelength. That said, it's the only game in town for a 3.0nm at that price point and I'm satisfied with the purchase.
#11 John Vogt
John Vogt
Posted 20 June 2021 - 07:43 PM
Hi longbond,
Thanks for the additional input. If I obtain either a 100mm or 135mm lens I might go f/2.8
and forgo f/1.8 so the filter could still be front mounted.
I'm waiting for a Televue 67/55mm combo to arrive. Obviously the 3nm will be mounted on the front
of that combo.
