Mak 180 astrophoto - question
7 replies to this topic
#1 planedriver
planedriver
Posted 20 June 2021 - 02:42 AM
Hi all,
We enjoy the Skymax 180 a lot when it comes to astrophotography however time to time our stars are gettin strange - one of their sides get flat.
This does not happen all the time, so far these two cases were prominent - any suggestion ?
A
#2 luxo II
luxo II
  • Loc: Sydney, Australia
Posted 20 June 2021 - 02:50 AM
In the third one all the stars are slightly elongated in the same direction which suggests a tracking error, or possibly flexure.
#3 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 20 June 2021 - 02:58 AM
Could be number of things - collimation, guiding etc.
Your scope has a lot of focal length.
How is your guiding?
Does it show in short exposure?
Have you checked collimation?
#4 planedriver
planedriver
Posted 20 June 2021 - 03:15 AM
This is a good point - need to try OAG
Collimation - star test is concentric although I'm far from expert in this area so try not to spend too much time with it. Also other in cases stars are round , definitely no sign of the described - see attached pics - same setup, guiding, exposure equipment
Will check short exposure - another good point.
#5 PETER DREW
PETER DREW
Posted 20 June 2021 - 06:31 AM
I would suspect a tilted plane somewhere in the imaging train.
#6 Rasfahan
Rasfahan
  • Loc: Hessen, Germany
Posted 21 June 2021 - 06:52 AM
It‘s a bit difficult to tell with the stacked images. Stretched single frames from dense starfields will be easier. But I do not see even distortions in the field, which points to miscollimation instead of tracking/flex issue. In the last image the stars are far larger than in the first two - this can be focus or seeing, masking the issue. If it really is intermittent, it could be a stressed mirror or corrector, due to temperature. To rule out tracking/flex take some very short and some longer exposures and see if the elongation gets worse with more exposures time.
If your parameters for guiding are correct (FL, pixel size), this is very good - what mount are you using?
#7 planedriver
planedriver
Posted 21 June 2021 - 09:31 AM
This is something I need to look at.
Thanks for the feedback - the ones posted are cropped a bit. I have attached two single frames instead of the stacked image.
This is a belt driven HEQ-5.
#8 lakeorion
lakeorion
  • Loc: Lake Orion MI
Posted 23 June 2021 - 12:40 PM
Another possibility is mirror flop?  Are you focusing the mirror in the same direction all the time?
Great examples though with this long focal length / high f-ratio.  I have a 180 and I haven't considered trying deep sky AP.  Someday I'll give lunar / planetary a try but I don't have the patience for f15 deep sky...
