Is this sensor tilt or something else?
4 replies to this topic
#1 mr1337
mr1337
  • Loc: NJ, USA
Posted 21 June 2021 - 03:25 PM
Trying to start using my 70mm Meade Quad with the ASI2600 and noticed the stars are a bit wonky in the corners... I'm familiar with having an out of collimation SCT or backfocus issues but I didn't think the petzval design would be inlcined to have the same backfocus problems.
Should I be adjusting tilt to help correct?
Mathew
#2 ew22
ew22
Posted 21 June 2021 - 03:30 PM
I am not an expert and recently am suspecting i have a tilt issue, but i would try adjust spacing first in your case.
#3 Gert
Gert
Posted 21 June 2021 - 03:38 PM
Hi Mathew,
I've seen similar with ASI2600MC and the canon 200mm F2.8 lens.
The following helped me
  • Carefully removing the tilt plate from the camera and inspecting if it was attached properly. I found a small spec of debris that was caught between camera body and the tilt plate and removed it.
  • Carefully feeling the tapped holes in the camera body for any rims or burrs. I thought I felt some and covered the camera opening with tape and used a small flat key file to remove the burrs. Same for the tilt plate.
  • Taking test exposures and adjusting the tilt plate.
Gert
#4 mr1337
mr1337
  • Loc: NJ, USA
Posted 22 June 2021 - 11:04 AM
Thanks all - will give it a shot and report back.
#5 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 22 June 2021 - 11:29 AM
With the Petzval design there is NO spacing requirement. I have two Petzval scopes and all that you do or need to do is to focus them. So, in this case, either the scope is terrible or there's a combination of tilt, focusing and poor correction going on. If the spec says that is can cover an APS-C chip and it's a new scope, I'd be sending it back after doing a bit of further checking. Don't hold onto it beyond the time when it can be returned.
