NINA Sequencer - Framing Assistant
3 replies to this topic
#1 dcm_guitar
dcm_guitar
Posted 21 June 2021 - 05:44 PM
I've never used the framing assistant in NINA.
I'd like to change the center of a target for a sequence.  I want to get a photo of the Pillars of Creation.  So, I put M16 into the Framing Assistant, and then altered the center.  I see the coordinates change.
I add this to the new sequencer.
In my sequencer in the "Loop Conditions" section (right below the "Triggers" section) I have two conditions that I always use:
  1. Wait for altitude>=30 degrees
  2. Solve and Sync
Because I have altered the normal center of M16, do I need to remove this "Solve and Sync" instruction.  Or, will it Solve and Sync to the new coordinates that I have found using the Framing Assistant?
Thoughts?
#2 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 21 June 2021 - 05:58 PM
Have you posted on NINA Discord forum?
https://discord.com/invite/rWRbVbw
#3 jerahian
jerahian
  • Loc: Maine
It will solve and sync to the new location, which is basically what should be in the “Target” portion of your sequence.
  • limeyx and dcm_guitar like this
#4 dcm_guitar
dcm_guitar
Posted 21 June 2021 - 06:02 PM
 I really do NOT like getting assistance from the Discord server.  Yes, I have posted there before.
