Astroberry su password
8 replies to this topic
#1 Wm Rison
Wm Rison
  • Loc: Newburg, Maryland
Posted 22 June 2021 - 11:15 AM
I want to change the network mask for eth0.
When I do the ifconfig eth0 192.250.0.2 netmask 255.255.255.0 (what I need it to be) I get Operation not permitted.
So I try and change to super user with the su command.
su fails with authentication failure
Tried astroberry and raspberry as passwords, no luck.
Looked at the document on astroberry.io it was not any help.
Does anyone know the su passwrod for astroberry?
William
#2 astrokeith
astrokeith
  • Loc: Surrey, UK
Posted 22 June 2021 - 11:40 AM
Weird. My default passwords work.
Have you tried a straight
sudo ifconfig <network name> <IP> net mask <mask>
#3 eits
eits
  • Loc: 31N 110W (SE Arizona, USA)
Posted 22 June 2021 - 12:38 PM
I am by no means an IP expert. Your request puzzles me a bit. First of all, your su (super user) password should have been set when you installed the computer. Secondly, the sudo command, if available, usually requires your user id to be set in the sudo users config file (found in the /etc directory on fedora). Thirdly, if your eth0 is connected to the internet your attempted ifconfig change is going to cause problems since the IP range 192.250.0.0 - 192.250.15.255 is registered to the OTIS Elevator Company. WHOIS 192.250.0.2 will show this. If your eth0 is only connected to a local network I would expect you would be using one of the private IP ranges 10.0.0.0 - 10.255.255.255 or 172.16.0.0 - 172.31.255.255 or 192.168.0.0 - 192.168.255.255
-gary-
#4 Lasko
Lasko
  • Loc: Sacramento, CA
Posted 22 June 2021 - 01:47 PM
Can you confirm you are trying to use the wired connection, and what is the network you are connecting to?  Usually DHCP will handle assigning the address.
If you need to set the address manually you can do that with the "Edit Connections" menu.
#5 Dan Crowson
Dan Crowson
  • Loc: Dardenne Prairie, MO
Posted 22 June 2021 - 01:52 PM
You could just change it:
sudo passwd root
Dan
  • Kevin Ross likes this
#6 Wm Rison
Wm Rison
Posted 22 June 2021 - 05:32 PM
Thanks everyone for the information.
I made a mistake with the IP address I was wanting to use.
Should have been 169.254.0.2 mask 255.255.0.0
It turns out I just did now wait long enough for the address to be set correctly.
Eth0 is connected directly to my Starbook Ten.
Also when I do a sudo ifconfig and am asked for a password astroberry works as the password.
Just issuing an su command and typing in the same password fails.
The sudo works for me.
Just to clear things I did not configure any parameters on my Raspberry Pi 4 because this is the astroberry image.
This is the first time I have worked with the Raspberry Pi and any unix type os for a very long time.
I do a lot of windows visual basic programming.
Thanks again,
William
#7 astrokeith
astrokeith
  • Loc: Surrey, UK
Posted 22 June 2021 - 05:43 PM
Thanks again,
William
Glad you got it fixed.
I got hooked on Pi's - enjoy the learning.
Keith
#8 TelescopeGreg
TelescopeGreg
  • Loc: Auburn, California, USA
Posted 22 June 2021 - 10:44 PM
You can also right-click on the network icon on the toolbar at the top, and select "Edit connections".  Select the Eth0 row, hit the "settings" icon at the bottom (the star-shaped thingy), and fill in whatever you need to set under the IPv4 settings tab.
You can also have the Pi become the DHCP server for the external devices (and not rely on the kludgy self-assigned addressing) by changing the IPv4 "Method" from DHCP to "Shared to other computers".
But, if you have it working to your satisfaction, what you've done can work too.  Note that making a change with ifconfig is temporary (reverts on reboot) unless you're setting it in a system configuration script somewhere.  If that's the case, using the established GUI interface (above) is much better.
#9 gmiller123456
gmiller123456
Posted 22 June 2021 - 11:00 PM
For future reference, "sudo" asks for your own password, "su" asks for the "root" password.  It is pretty rare nowdays that you really want to use "su".
