lx90 autostar controler coil cable coming apart.
Meade Mount
9 replies to this topic
#1 djmalone4
djmalone4
Posted 23 June 2021 - 04:41 PM
Have a older (15year) Meade LX90 with autostar. The coil cable is comming apart as the insulation is going bad. Thought about using a cat5 computer network cable?? Taped up, but needs replaced. Any ideas.
#2 OzAndrewJ
OzAndrewJ
Posted 23 June 2021 - 05:33 PM
Gday djmalone4
DO NOT use a std cat5 cable.
The Meade handbox cable is wired differently
ie cat 5 is wired 1-1..8-8
Meade is wired 1-8..8-1
  • Dynan likes this
#3 Mitchell M.
Mitchell M.
  • Loc: Mountains of Western NC
Posted 23 June 2021 - 05:42 PM
I ordered a new one for mine some months ago, if I remember correctly, from AgenaAstro.
#4 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 23 June 2021 - 05:43 PM
Moving from Mounts to Meade Computer Telescopes for a better fit.
#5 kg74
kg74
Posted 23 June 2021 - 09:47 PM
OzAndrewJ - if one was to make their own cable using cat 5 wire and ends what would the order be?  Is there a diagram or link you have handy?
OP - I have used self-bonding silicon stretch tape to repair similar problems, although it leaves an inflexible end.
Would this work?
https://www.cloudyni...e +pin +diagram
Edited by kg74, 23 June 2021 - 09:50 PM.
#6 OzAndrewJ
OzAndrewJ
Posted 23 June 2021 - 11:20 PM
Gday kg74
As per above, if you have cat 5 cable and RJ45 connectors, the wires used are to all intents and purposes irrelevant, you just want it wired 1-8..8-1
http://web.archive.o...rg/pinouts.html
Would this work?
Looks correct for use as a 497 Hbx
#7 Oberon510
Oberon510
  • Loc: Santa Cruz, California, USA
Posted 23 June 2021 - 11:31 PM
I got mine from Agena Astro the same as Mitchell's comment - they have 8 in stock at $19 each.
https://agenaastro.c...ble-808012.html
#8 rmollise
Posted 25 June 2021 - 03:38 PM
Same thing happened to my ETX125PE cable (about 16 years old). It's easy enough to wire up a new one, but, being lazy and not knowing where my RJ crimper was at the moment, I just ordered one from Agena Astro.
#9 Mitchell M.
Mitchell M.
Posted 25 June 2021 - 11:06 PM
ScopeStuff also has a extra-long (14' extended length) replacement coil cable for the AutoStar II for $21.00.
#10 Geo.
Geo.
    Vendor - Nexstar Parts
  • Loc: Upstate NY
Posted 11 July 2021 - 10:38 PM
These are Rj11/12 6P/6C, but the concept is the same for 8P8C RJ-45 cables. You want straight through for most astronomy uses as they are data cable not telephony.
Also tagged with one or more of these keywords: Meade, Mount
